Discuss
Problem with Goodman/Janitrol Furnace
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hello all, this is my first post to the forums and I could really use some help. Last week my
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Problem with Goodman/Janitrol Furnace
  #1 (permalink)
Old 06-23-2011, 11:43 PM
Junior Member
brianmacho is on a distinguished road
Question Problem with Goodman/Janitrol Furnace
Brand: -other-   Age: 5 - 10 years
Hello all, this is my first post to the forums and I could really use some help. Last week my blower fan in the furnace/AC unit would not run. After some checking, I realized that the fan would run for approx 5 sec, then quit. No codes on the control board, solid red light. Then suddenly I had no lights on the board, totally dead.
Ok, I may have jumped the gun, I replaced the board without checking the voltage coming into the unit, same problem. I removed the cover from the door switch, and when I measure the AC voltage coming into the unit, I get 2.5v @ 60hz. WOW something is wrong!
Ok, so I checked the breaker, even swapped breakers, no change, so I have voltage into the house. Tracing the conduit back from the furnace I think I may have found the problem. the conduit runs from the breaker, into a box on my basement ceiling, like a switch box but with a small transformer on it, next to a switch in another box next to it. If it flip the switch, the voltage to the furnace goes to zero. Ok, so this mystery transformer is supplying voltage to what??? The thermostat maybe? There is a pair of brown small gauge wires coming off of it and running upstairs.
My guess is that the high voltage side of the transformer is shot, but what kind of transformer would this be and do I need it or can I bypass it and put the thermostat onto the 24v on the transformer inside of the furnace? Maybe this doesnt even go to the thermostat?
Any help would be appreciated as I need this fixed ASAP....93 degrees tomorrow and my wife isn't very happy!!!!!!!!!!!!
Thanks,
Brian
Ads By Google
  #2 (permalink)
Old 06-25-2011, 08:28 AM
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
Thanks,
Brian
Model and Serial number please. Without that cannot trace wires.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor.
a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
intermittent furnace problem depa007 Heating, Ventilation, and Air Conditioning (HVAC) 0 12-10-2009 02:28 PM
Furnace motor capacitor problem fixed! franky Heating, Ventilation, and Air Conditioning (HVAC) 0 07-18-2009 01:55 PM
goodman ac. condener 69firebird Heating, Ventilation, and Air Conditioning (HVAC) 2 05-14-2009 05:24 PM
furnace problem!!!! jeremy69 Heating, Ventilation, and Air Conditioning (HVAC) 2 02-07-2009 04:07 PM
Hot air furnace problem. RegB Heating, Ventilation, and Air Conditioning (HVAC) 8 03-18-2008 07:52 PM
