when i turn on my air conditioner unit the fan will start running as normal. then when its time for the compresser to start the fan shuts off right away when the compressor comes on. the compressor will still run and i can see and feel the core getting cold but the fan is not running. then i need to shut down the power because i'm afraid i will damage the unit worse then what it already is.when i start it up again it does the same thing i just described everytime. can someone help?
thank you, hardpack6321
