Discuss
a/c wall unit
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Reaches set temp but does not shut off? This is my 1st wall unit.Shouldn't it shut off when it reaches
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » a/c wall unit
  #1 (permalink)
Old 05-27-2011, 04:44 PM
Junior Member
Dfoul is on a distinguished road
Default a/c wall unit
Brand: GE   Age: Less than 1 year
Reaches set temp but does not shut off? This is my 1st wall unit.Shouldn't it shut off when it reaches temp?Does the condensor shut off on these and the fan keep running?? Will appreciate any help on this.
Ads By Google
  #2 (permalink)
Old 06-04-2011, 08:38 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Check your operators manual.
A model number may help others help you.
GE makes a lot of different units.
If you do not have the operators manual you may be able to download it from the GE site but you will need the model number.
As far as shutting the compressor off but leaving the fan on, that is possible.
Usually you can hear when the compressor is running.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
adapt window unit to wall sunshine47 Heating, Ventilation, and Air Conditioning (HVAC) 0 04-23-2010 06:43 AM
Help with Kenmore thru-the-wall AC unit patrick44107 Heating, Ventilation, and Air Conditioning (HVAC) 5 11-10-2009 07:00 PM
Gaffers & Sattler Wall unit Smithunlimited Oven Repair (including Ranges and Cooktops) 0 10-26-2009 05:36 PM
Ge Oven Wall Unit GEUSEROVEN Oven Repair (including Ranges and Cooktops) 1 05-31-2009 06:11 PM
Heat Not Working In Wall Unit rossjason474 Heating, Ventilation, and Air Conditioning (HVAC) 1 09-12-2008 09:16 PM
