Discuss
Furnace Not Igniting Quickly?
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Turn off the power at the furnace, jump w -r ( white wire to red ) that comes from t/stat, (24
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Furnace Not Igniting Quickly?
  #11 (permalink)
Old 01-09-2009, 02:52 AM
ernesto1959 ernesto1959 is offline
Junior Member
ernesto1959 is on a distinguished road
Default t/shoot
Turn off the power at the furnace, jump w -r ( white wire to red ) that comes from t/stat, (24 volts) , colors may not match but terminals in unit , yes so jump w-r...... T/stat must be in off position and fan in off . turn on the power and just heating mode need to come on; fan must be off. take the time , must be on really quick just when powered. ..must hold unit burning for a couple of minutes and then the fan must turn on.
  #12 (permalink)
Old 01-09-2009, 07:43 AM
icehouse icehouse is offline
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
Amazing that OP asked about "fan control' and gets a thermostat procedure.
Anyhow :
Combination Fan & Limit Control: This control turns the furnace blower on and off at the proper times. The FAN ON setting on this control makes sure that the blower fan does not turn on (even though the building thermostat has asked for heat) so that the furnace wont' blow cool air into the occupied space.
Furnace FAN ON: When an adequate warm temperature has been reached inside of the furnace warm air plenum chamber the FAN ON switch turns on the furnace blower to deliver warm air to the occupied space.
Furnace FAN OFF: The furnace combination fan and limit control FAN OFF setting lets the furnace blower continue to run for an interval after the furnace burner has turned off, but will shut the blower off after the heat exchanger has been cooled down and the heat it contained has been sent to the occupied space.
Furnace LIMIT: The LIMIT indicator setting is a safety control that will turn off the oil or gas burner if temperatures inside the warm air plenum exceed a safe level.
When does the furnace blower turn OFF in normal operation?
When the thermostat has been satisfied and turns off the oil or gas burner at the furnace, the fan limit switch will cause the blower or fan unit to continue to operate until the temperature at the supply plenum has reached or dropped below the "cut-in" or "fan-on" lower limit on the switch.
When does the furnace oil burner, gas burner, or other heat source turn OFF in normal operation:
On most heating systems the burner or heat source will continue to run all of the time that the building thermostat is asking for heat, and will stop running as soon as the thermostat is satisfied. If the furnace oil or gas burner is very high capacity, or if the furnace fan/limit controls have been set to cause this effect, the burner may on some systems cycle on and off periodically while the warm air blower continues to run.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor. Vist www.hvacbob.com
  #13 (permalink)
Old 01-09-2009, 03:09 PM
Junior Member
Default ASK Them
Quote:
Originally Posted by IdahoBiker View Post
Well at this Point the Blower is Coming on 1st (Hi-Speed // 2-speed Motor)
then after 10-12 minutes the furnace starts the ignition process...so HOW do I correct this Problem? When the Blower Motor was Changed out, the Serviceman swapped out the Old Motor with the New, and informed me that The wiring was different, but that He knew How to correct that, as he had done that many times, I'm wondering If he got his Wires Crossed, pardon the Pun. the Bottom Line is I have a Lot of $$$ tied up in New Parts, and just want it to work right.In response to the "Set-Delay", it's NOT doing that: It comes On, and goes Out (repeats this Process 6-9 times, before It Ignites Constant) So what do I need to do to Troubleshoot & Repair?
Any ideas on WHERE? I can attain a Parts Schematic for this Furnace? It's a Model 397HAW036060 Day & Night (Manufacturer. by Carrier) in 1982
"day and night comfort.com " is the web site or call carrier (totaline stores) they have a website.
  #14 (permalink)
Old 11-07-2009, 10:17 AM
handsoff handsoff is offline
Junior Member
handsoff is on a distinguished road
Default
Apart from tearing the furnace apart what else can we do but replace it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Heating Furnace ceci Heating, Ventilation, and Air Conditioning (HVAC) 2 10-30-2008 07:44 PM
Gas Oven NOT Igniting Ray Clow Oven Repair (including Ranges and Cooktops) 7 10-07-2008 04:10 PM
Not chewing up food quickly caryb1975 Garbage Disposer Repair 0 10-04-2008 01:51 PM
Amana washer hot smell and does not brake quickly at end of spin cycle RandyToby1 Washer Repair 0 03-21-2008 06:59 PM
furnace no heat amati5 Heating, Ventilation, and Air Conditioning (HVAC) 0 11-28-2007 02:46 PM
