| » Noisy Furnace Fan |
Model Number: 867.587741 Brand: Sears Age: More than 10 years
My mother has a 35 year old electric Sears Furnace. It heats fine, but the fan (or something) makes noises and perhaps a heavy vibration in the plenem (spelling) for a couple of seconds on start up, then appears to run smooth and balanced in the heating phase. When shutting down, the nosie starts up again making a dit, dit, diiittt, ddddddiiiitttt, sound as the fan slows to a stop.
When I open the access panel and manually spin the fan it makes a dragging sound as if the fan is dragging on the housing as some point around it's circumfrance. So I do not suspect the motor itself. Perhaps the fan bearings are failing and causing some unbalanced rotation at slow speeds. 1. Thoughts on the diagnosis? 2. Where can I get parts for such an old beast? 3. How would I go about fining someone knowledgible and capable to repair this old furnance. Or should I just do it? |
If the unit is 120 V , may not use a capacitor, but put current off, take away the whole fan casing and pull the wheel , motor and take it to
Sounds like the bearings in the blower wheel are shot.
Quote:
I have seen seen where I can purchase PT# 601211 from Searspartsdirect.com, but am not sure the bears will come with the part. |
Thanks for the reply. You are on my page, in thinking it is only the bearings. I found that I can purchase a blower wheel from Searspartsdirect.com, but not sure it would come with bearings. I called them and talked to a lady. Not to be sexist, but she knew less about this stuff than I do and had zero mechanical sense. So getting the information I need is tough. Do you know if blower wheels typically come with the bearings? For $80, I suppose I could just risk it and order the wheel.
Model # 867.587751
Part # 601211 Make sure you grab the motor shaft and move it around. This will check motor bearings. |
| Display Modes | |
| Furnace runs high, AC does not | fuchs1bl | Heating, Ventilation, and Air Conditioning (HVAC) | 11 | 11-21-2008 04:58 AM |
| Ge Heating Furnace | ceci | Heating, Ventilation, and Air Conditioning (HVAC) | 2 | 10-30-2008 06:44 PM |
| Hot air furnace problem. | RegB | Heating, Ventilation, and Air Conditioning (HVAC) | 8 | 03-18-2008 07:52 PM |
| Anyone Know How To Restart Frigidaire Furnace??? | frg422 | General Talk | 0 | 01-02-2008 08:34 PM |
| furnace no heat | amati5 | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 11-28-2007 01:46 PM |
