Discuss
Relay switch wont engage automaticaly to turn ac on per thermostat
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hi, I have a old 1976 made Tappan CM 24-43 T AC unit and recently it wont turn on at
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Relay switch wont engage automaticaly to turn ac on per thermostat
  #1 (permalink)
Old 07-27-2007, 07:52 AM
Junior Member
lolo is on a distinguished road
Default Relay switch wont engage automaticaly to turn ac on per thermostat
Model Number: CM 24-43-T   Brand: Tappan   Age: More than 10 years
Hi, I have a old 1976 made Tappan CM 24-43 T AC unit and recently it wont turn on at all. What i did i got inside of it and was able to manualy engage a spring loaded switch and ac would come on fine. i am trying to find out what could cause the unit not to turn on automaticaly per thermostat and what would be the solution and if it is cost effective (i am not sure how much would a new ac cost for a 1000sq ft ranch)
Ads By Google
Related Models
Whirlpool CM02743BL1
Jenn-Air CM100 Surface Base Unit - Ddraft Ele
Jenn-Air CM100-E Surface Base Unit - Ddraft Ele
Crosley CM151 Mwave - Cntrtp / Stand Alone
Crosley CM153 Mwave - Cntrtp / Stand Alone
Magic Chef CM15K-7BS-NB Mwave - Mounted Over Range/wo
Magic Chef CM15KW-7BS-NB Mwave - Mounted Over Range/wo
Jenn-Air CM200 Surface Base Unit - Ddraft Ele
Jenn-Air CM200-E Surface Base Unit - Ddraft Ele
Thermador CM301B
Thermador CM301S
Thermador CM301W
Thermador CM302B
Thermador CM302S
Thermador CM302W
Crosley CM464G Mwave - Cntrtp / Stand Alone
Magic Chef CM46B-9P Mwave - Mounted Over Range/wo
Magic Chef CM46B-9P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46D-8P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46D-9P Mwave - Mounted Over Range/wo
Magic Chef CM46D-9P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46F-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46F-8P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46FN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46FN-8P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46G-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46GN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46H-14T Mwave - Mounted Over Range/wo
Magic Chef CM46HW-14T Mwave - Mounted Over Range/wo
Magic Chef CM47F-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM47FN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM47H-14T Mwave - Mounted Over Range/wo
Magic Chef CM47HW-14T Mwave - Mounted Over Range/wo
Magic Chef CM47J-14T Mwave - Mounted Over Range/wo
Magic Chef CM47JW-14T Mwave - Mounted Over Range/wo
Magic Chef CM48F-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM48FN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM48H-14T Mwave - Mounted Over Range/wo
Magic Chef CM48HW-14T Mwave - Mounted Over Range/wo
Magic Chef CM48J-14T Mwave - Mounted Over Range/wo
Magic Chef CM48JW-14T Mwave - Mounted Over Range/wo
Amana CM601.000 Commercial Microwaves
Amana CM601.A Commercial Microwaves
Hardwick CM9641A590R Range - F/s Std Gas
Hardwick CM9641W590R Range - F/s Std Gas
Hardwick CM9641Y590R Range - F/s Std Gas
Amana CMA2000 Commercial Microwaves
Amana CMA2000B3 Commercial Microwaves
Amana CMA2000BK Commercial Microwaves
Amana CMA2230 Commercial Microwaves
Amana CMA2230B3 Commercial Microwaves
Maytag CME300 Mwave - Cntrtp / Stand Alone
Maytag CME301 Mwave - Cntrtp / Stand Alone
Maytag CME400 Mwave - Cntrtp / Stand Alone
Maytag CME500 Mwave - Cntrtp / Stand Alone
Maytag CME501 Mwave - Cntrtp / Stand Alone
Maytag CME601 Mwave - Cntrtp / Stand Alone
Maytag CME700 Mwave - Cntrtp / Stand Alone
Maytag CME701 Mwave - Cntrtp / Stand Alone
Maytag CME800 Mwave - Cntrtp / Stand Alone
Maytag CME8000AAB Mwave - Cntrtp / Stand Alone
Maytag CME8000AAE Mwave - Cntrtp / Stand Alone
Maytag CME8010AAB Mwave - Cntrtp / Stand Alone
Maytag CME8010AAE Mwave - Cntrtp / Stand Alone
Maytag CME900 Mwave - Cntrtp / Stand Alone
Maytag CME901 Mwave - Mounted Under Cabinet
Maytag CME9010AAB Mwave - Mounted Under Cabinet
Maytag CME9010AAE Mwave - Mounted Under Cabinet
Maytag CME9010BAB Mwave - Mounted Under Cabinet
Maytag CME9010BAE Mwave - Mounted Under Cabinet
Maytag CME9010CAB Mwave - Mounted Under Cabinet
Maytag CME9010CAE Mwave - Mounted Under Cabinet
Maytag CME9010CAM Mwave - Mounted Under Cabinet
Maytag CME9010DAB Mwave - Mounted Under Cabinet
Maytag CME9010DAE Mwave - Mounted Under Cabinet
Uni CMEF212EB1 Universal Canada/electric Range
Uni CMEF212EB2 Universal Canada/electric Range
Uni CMEF212EB3 Universal Canada/electric Range
Uni CMEF212EQ1 Universal Canada/electric Range
Uni CMEF212ES1 Universal Canada/electric Range
Uni CMEF212ES2 Universal Canada/electric Range
Amana CMM2000C Commercial Microwaves
Menu Master CMM2000C  Commercial Microwaves
Amana CMM2000CS Commercial Microwaves
Amana CMM2230C Commercial Microwaves
Amana CMM2230CS Commercial Microwaves
Amana CMP1.A Commercial Microwaves
Maytag CMS130BCLWH  Freezer - Vertical
Maytag CMS180BCLWH  Freezer - Vertical
Maytag CMS210ACLWH Freezer - Vertical
Maytag CMS210ADLWH Freezer - Vertical
Maytag CMS210BCLWH Freezer - Vertical
Thermador CMT-127
Thermador CMT-131
Thermador CMT-18
Thermador CMT-19
Thermador CMT-19 SERVICE CODE H & UP
Thermador CMT-20
Thermador CMT-21
Thermador CMT-21 SERVICE CODE J & UP
Thermador CMT-227
Thermador CMT-231
Whirlpool CMT061SGW0
Whirlpool CMT101SGW0
Whirlpool CMT102SGW0
Thermador CMT127N-01
Whirlpool CMT135SGW0
Thermador CMT227N-01
Thermador CMT227W
Thermador CMT231-01 S/N 89110145 & UP
Maytag CMV1000ADA Mwave - Mounted Under Cabinet
Maytag CMV1000ADB Mwave - Mounted Under Cabinet
Maytag CMV1000ADW Mwave - Mounted Under Cabinet
Maytag CMV1000BAB Mwave - Mounted Under Cabinet
Maytag CMV1000BAQ Mwave - Mounted Under Cabinet
Maytag CMV1000BAW Mwave - Mounted Under Cabinet
Maytag CMV1000BDB Mwave - Mounted Under Cabinet
Maytag CMV1000BDQ Mwave - Mounted Under Cabinet
Maytag CMV1000BDW Mwave - Mounted Under Cabinet
Maytag CMV1100AAB Mwave - Mounted Under Cabinet
  #2 (permalink)
Old 07-27-2007, 01:06 PM
Member
jdman is on a distinguished road
Default
The contactor coil is bad. When it goes bad itn will not pull in the contacts. When you manually push it in it works but will not hold. replace contactor and all will be well. Not expensive or hard to do. Just replace with same as you take out. ie single pole or double pole.
  #3 (permalink)
Old 07-27-2007, 03:35 PM
Administrator
APP Team
Adam / APP Team is on a distinguished road
Default
Dear lolo,
I was unable to get your model to come up. Possibly due to the age.
In most cases it does have to do with the contactor. You might try that before having a technician come to your home.
To get a new contactor you might see if there are any numbers off the old part.
  #4 (permalink)
Old 01-16-2008, 05:56 PM
Junior Member
protk1 is on a distinguished road
Default
Could be a bad thermostat. Check the coil voltage(24-28vac) @ terminals on each side of contactor. If you don't have this voltage the contactor (relay) won't pull in. Be safe!
  #5 (permalink)
Old 07-20-2010, 05:59 PM
Junior Member
calzone8 is on a distinguished road
Default relay contactor coil gone bad
I have same problem with a old model granita machine i have side by side relays one will not engage i took it out to try and find manufacturer but no one can figure out who it is the only description is R-O the contact coil is fused on to the rear of the sprng loaded relay and cannot be removed with breaking it open any suggestions
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermostat or Switch? chuckhaig Oven Repair (including Ranges and Cooktops) 1 04-07-2009 02:26 PM
generic relay switch arniedog Refrigerator & Freezer Repair 0 01-24-2009 06:11 PM
Oven Thermostat switch goes on and off by itself Judy B Oven Repair (including Ranges and Cooktops) 1 03-27-2008 06:45 PM
Relay verses Switch Control Panel Boater Oven Repair (including Ranges and Cooktops) 2 03-05-2008 08:34 AM
Wire configuration for relay/ovrload switch Brian Olsen Refrigerator & Freezer Repair 3 01-06-2008 02:28 AM
