Discuss
Relay switch wont engage automaticaly to turn ac on per thermostat
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hi, I have a old 1976 made Tappan CM 24-43 T AC unit and recently it wont turn on
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Relay switch wont engage automaticaly to turn ac on per thermostat
  #1 (permalink)
Old 07-27-2007, 08:52 AM
lolo lolo is offline
Junior Member
lolo is on a distinguished road
Default Relay switch wont engage automaticaly to turn ac on per thermostat
Model Number: CM 24-43-T   Brand: Tappan   Age: More than 10 years
Hi, I have a old 1976 made Tappan CM 24-43 T AC unit and recently it wont turn on at all. What i did i got inside of it and was able to manualy engage a spring loaded switch and ac would come on fine. i am trying to find out what could cause the unit not to turn on automaticaly per thermostat and what would be the solution and if it is cost effective (i am not sure how much would a new ac cost for a 1000sq ft ranch)
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-27-2007, 02:06 PM
jdman jdman is offline
Member
jdman is on a distinguished road
Default
The contactor coil is bad. When it goes bad itn will not pull in the contacts. When you manually push it in it works but will not hold. replace contactor and all will be well. Not expensive or hard to do. Just replace with same as you take out. ie single pole or double pole.
  #3 (permalink)
Old 07-27-2007, 04:35 PM
Adam / APP Team Adam / APP Team is offline
Service Pro
APP Team
Adam / APP Team is on a distinguished road
Default
Dear lolo,
I was unable to get your model to come up. Possibly due to the age.
In most cases it does have to do with the contactor. You might try that before having a technician come to your home.
To get a new contactor you might see if there are any numbers off the old part.
  #4 (permalink)
Old 01-16-2008, 06:56 PM
protk1 protk1 is offline
Junior Member
protk1 is on a distinguished road
Default
Could be a bad thermostat. Check the coil voltage(24-28vac) @ terminals on each side of contactor. If you don't have this voltage the contactor (relay) won't pull in. Be safe!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
changing thermostat ratboy915 Oven Repair (including Ranges and Cooktops) 3 07-27-2007 09:47 AM
My dryer blows hot air but doesn't turn. staceyo Dryer Repair 1 07-26-2007 08:45 PM
Thermostat or Fan problem equon, equon00@yahoo.com Refrigerator & Freezer Repair 0 07-25-2007 01:33 PM
Lid Switch CAN I DO IT Washer Repair 0 07-24-2007 05:56 PM
change out the lid switch jreythomas@hotmail.com Washer Repair 1 07-20-2007 06:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
