Discuss
Trane XE 90 pressure switch
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Helping a friend that bought a house with this furnace. It was not running right as the red wire for
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Trane XE 90 pressure switch
  #1 (permalink)
Old 02-26-2011, 10:52 PM
Junior Member
ldpfeifer is on a distinguished road
Default Trane XE 90 pressure switch
Brand: -brand-   Age: 5 - 10 years
Helping a friend that bought a house with this furnace. It was not running right as the red wire for the t stat was not hooked up. I opened the unit as I was getting 3 red lights for the pressure switch being stuck open. I held it closed with my knife and it fired off, then 2 lights for being stuck closed. I removed the P switch and shook it a bit and put it back on. There is a connection for the clear air hose in the back and in the front of the pressure switch. The back hose was installed but the front hose was off. I got the unit to run with this hose off but am not sure if it is suppose to be off or on. When installed the furnace fires off then quits and give me the 3 lights. Off, it runs fine. Any one know if this is to be on or off? If its suppose to be on, the switch is most likely bad.
Thanks in advance,
Lyle
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing Pressure Switch TomKrup Dishwasher Repair 0 01-06-2011 09:05 AM
Is this a bad pressure switch... again? sneiss Washer Repair 1 01-05-2011 10:31 AM
How to test pressure switch? FOXEYFIXIT Washer Repair 2 07-25-2010 06:30 AM
Pressure switch failure walterwaterpolo Washer Repair 0 11-07-2009 07:11 AM
Pressure Switch Replacement trnash9 Washer Repair 2 10-29-2009 11:18 AM
