| » Trane HP indoor relay sparking |
Model Number: TWV025B104A Brand: -brand- Age: More than 10 years
Trane 2 ton HP. Indoor unit contactor started buzzing and fluttering. Fan continued to run but outdoor unit and elcetric heat would not . Suspected 24 v T-former but voltage checked out. Replaced time delay and relay. With T-stat in heat mode and on emerg heat fan would run but no heater contactor engagement. 24 v going to electric heat contactor. Can hold contactor in and will heat. If T-stat is placed in normal mode, outdoor unit will cyle on for about one second and off and 24v t_former starts overheating as though a short is being applied. Question. 1. why would electric heat contactor not engage with 24v applied? 2. could t-stat be shorting. 3. Outdoor unit will run if its contactor is manually held in. 4. I diconnected all t-stat wiring to outdoor hoping to just have fan and electric heat. Fan runs but electric heat contactor will not engage. Can I assume that contactor is bad? The unit is a TWV025B104A mfgrd in 1996. All ran fine until the indoor relay started rattling and sparking. I suspect a short either in the t-stat or in the outdoor unit. I would be okay with just indoor fan and back up electric heat for now. Any suggestions.
Jerry Ads By Google Related Models |
Check your Transformers VA
Volt amps (VA) is the effective power rating for a transformer. In the perfect transformer, the voltage and current (combined) applied at the primary will exactly equal the voltage and current (combined) on the secondary(s). Instructions Things You'll Need:
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor. a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/ |
| Display Modes | |
| Trane xe 80 no heat | robstuff | Heating, Ventilation, and Air Conditioning (HVAC) | 4 | 11-21-2010 08:16 AM |
| TRANE XB80 no heat! | tommyt37 | Heating, Ventilation, and Air Conditioning (HVAC) | 2 | 05-15-2010 09:07 PM |
| Motor relay sparking | jpyra | Dishwasher Repair | 1 | 03-02-2009 04:42 AM |
