Discuss
Old Carrier gas boiler melting spark ignitor
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have an old gas-fired steam boiler manufactured by Dunkirk for Carrier. It's a blue-green color with the burners exposed
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Old Carrier gas boiler melting spark ignitor
  #1 (permalink)
Old 01-25-2011, 05:45 PM
Junior Member
johnrdila is on a distinguished road
Default Old Carrier gas boiler melting spark ignitor
Model Number: 234D-5SB   Brand: -other-   Age: More than 10 years
I have an old gas-fired steam boiler manufactured by Dunkirk for Carrier. It's a blue-green color with the burners exposed at the bottom (i.e. no burner cover like on the new machines).
The spark ignitor (a plastic housed circuit board) is mounted on a metal plate on the front of the boiler about 6-8 inches above the opening to the burners. The heat from the burners climbs up the face of the boiler and heats the spark ignitor plastic housing and melts it.
I've replaced it once this winter and will need to replace it again before end of winter because it gets so badly melted that it interferes with its functionality. Is this machine supposed to have a cover over the burners (it doesn't look like it, but I have no idea)? If not, any explanations as to why the heat is coming out the front to the point of melting the ignitor housing? Do I need to adjust part of the draft system? I'd appreciate any insights. Pix here to make the problem more obvious.
Ads By Google
Related Models
Jenn-Air 2350EGS SURFACE UNIT- DDRAFT ELE
Roper 2354*0A Ranges, Electric*
Roper 2354*1A Ranges, Electric*
Roper 2354*2A Ranges, Electric*
Roper 2354*3A Ranges, Electric*
Roper 2354W0A Ranges, Electric*
Roper 2354W1A Ranges, Electric*
Roper 2354W2A Ranges, Electric*
Roper 2354W3A Ranges, Electric*
Roper 2356*0A Ranges, Electric*
Roper 2356W0A Ranges, Electric*
Jenn-Air 2360 SURFACE UNIT- DDRAFT ELE
Jenn-Air 2360EGS SURFACE UNIT- DDRAFT ELE
Jenn-Air 2361EGS SURFACE UNIT- DDRAFT ELE
Roper 2364*0A Ranges, Electric*
Roper 2364*1A Ranges, Electric*
Roper 2364*2A Ranges, Electric*
Roper 2364*3A Ranges, Electric*
Roper 2364W0A Ranges, Electric*
Roper 2364W1A Ranges, Electric*
Roper 2364W2A Ranges, Electric*
Roper 2364W3A Ranges, Electric*
Jenn-Air 2365 SURFACE UNIT- DDRAFT ELE
Jenn-Air 2365EGN SURFACE UNIT- DDRAFT ELE
Jenn-Air 2365EGS SURFACE UNIT- DDRAFT ELE
Jenn-Air 2366 SURFACE UNIT- DDRAFT ELE
Roper 2366*0A Ranges, Electric*
Roper 2366W0A Ranges, Electric*
Jenn-Air 2370 SURFACE UNIT- DDRAFT ELE
Jenn-Air 2370EGS SURFACE UNIT- DDRAFT ELE
Roper 2374*0A Ranges, Electric*
Roper 2374*1A Ranges, Electric*
Roper 2374*2A Ranges, Electric*
Roper 2374W0A Ranges, Electric*
Roper 2374W1A Ranges, Electric*
Roper 2374W2A Ranges, Electric*
Jenn-Air 2375ERS SURFACE UNIT- DDRAFT ELE
Roper 2376*0A Ranges, Electric*
Roper 2376W0A Ranges, Electric*
Jenn-Air 2380EGS SURFACE UNIT- DDRAFT ELE
Roper 2382*2A Ranges, Electric*
Roper 2382W2A Ranges, Electric*
Roper 2384*0A Ranges, Electric*
Roper 2384*1A Ranges, Electric*
Roper 2384*2A Ranges, Electric*
Roper 2384*3A Ranges, Electric*
Roper 2384W0A Ranges, Electric*
Roper 2384W1A Ranges, Electric*
Roper 2384W2A Ranges, Electric*
Roper 2384W3A Ranges, Electric*
Jenn-Air 2385EGN SURFACE UNIT- DDRAFT ELE
Jenn-Air 2385EGS SURFACE UNIT- DDRAFT ELE
Jenn-Air 2390ERS SURFACE UNIT- DDRAFT ELE
Roper 2406*0A Ranges, Electric*
Roper 2406*1A Ranges, Electric*
Roper 2406*2A Ranges, Electric*
Roper 2406*3A Ranges, Electric*
Roper 2406W0A Ranges, Electric*
Roper 2406W1A Ranges, Electric*
Roper 2406W2A Ranges, Electric*
Roper 2406W3A Ranges, Electric*
Frigidaire 2408A GAS RANGE
Frigidaire 2408B GAS RANGE
Frigidaire 2408C GAS RANGE
Frigidaire 2409A GAS RANGE
Roper 2413*0A Ranges, Electric*
Roper 2413W0A Ranges, Electric*
Roper 2414*0A Ranges, Electric*
Roper 2414*1A Ranges, Electric*
Roper 2414*2A Ranges, Electric*
Roper 2414W0A Ranges, Electric*
Roper 2414W1A Ranges, Electric*
Roper 2414W2A Ranges, Electric*
Frigidaire 2418A GAS RANGE
Frigidaire 2418B GAS RANGE
Frigidaire 2420A GAS RANGE
Roper 2424*0A Ranges, Electric*
Roper 2424*1A Ranges, Electric*
Roper 2424W0A Ranges, Electric*
Roper 2426*0A Ranges, Electric*
Roper 2426*1A Ranges, Electric*
Roper 2426*2A Ranges, Electric*
Roper 2426W0A Ranges, Electric*
Roper 2426W1A Ranges, Electric*
Roper 2426W2A Ranges, Electric*
Frigidaire 2427A GAS RANGE
Roper 2428000 Ranges, Electric*
Frigidaire 2428A GAS RANGE
Frigidaire 2428B GAS RANGE
Roper 2438000 Ranges, Electric*
Frigidaire 2438A GAS RANGE
Frigidaire 2440A GAS RANGE
Frigidaire 2447A GAS RANGE
General Electric 24488L0 Electric range
General Electric 24488W0 Electric range
Frigidaire 2448A GAS RANGE
Frigidaire 2448B GAS RANGE
Frigidaire 2450A GAS RANGE
Frigidaire 2450C GAS RANGE
Frigidaire 2450E GAS RANGE
Roper 2453*9A Ranges, Electric*
Roper 2453*AA Ranges, Electric*
Roper 2453W0A Ranges, Electric*
Roper 2453W9A Ranges, Electric*
Roper 2453WAA Ranges, Electric*
Roper 2454X0A Ranges, Electric*
Roper 2454X1A Ranges, Electric*
Roper 2454X2A Ranges, Electric*
Roper 2454X3A Ranges, Electric*
Roper 2456X0A Ranges, Electric*
Roper 2456X1A Ranges, Electric*
Roper 2456X2A Ranges, Electric*
General Electric 24588B0 Electric range
General Electric 24588L0 Electric range
General Electric 24588W0 Electric range
Frigidaire 2458A GAS RANGE
Frigidaire 2467A GAS RANGE
General Electric 24688B0 Electric range
General Electric 24688L0 Electric range
General Electric 24688W0 Electric range
  #2 (permalink)
Old 01-27-2011, 10:21 AM
Junior Member
SteveKJR is on a distinguished road
Default
It appears that the heat from the burners is causing the problem. Check to make sure your gass pressure going to the manifold is correct.
Also, check to see if there is an obstruction in the heat exchanger. This situation could cause flame rollout meaing that not all of the heat from the burners are going up through the heat exchanger.
Looking at the picture, it looks like the front above the burners is getting scorched. I am not that familiar with that particular boiler but I would think the burners should be tucked under the unit more to allow the flames from the burner to go up through the heat exchanger.
SteveKJR
  #3 (permalink)
Old 02-01-2011, 05:32 PM
Junior Member
Default
SteveKJR
Thanks for the reply. I agree with ur assessment. I found an old manual in the basement. The machine is circa 1981. From the photos I can see that the burner door is missing on my unit. I plan to make one out of metal to replicate the original. Case closed. Thanks again.
  #4 (permalink)
Old 02-01-2011, 09:37 PM
Junior Member
Default
Make sure you are getting a good draft at the burners. If you don't have a draft gauge, take a newspaper, roll it up and light it when the burners are lit.
Once it starts to burn blow it out, hold it about 6" away from the burners and see if the smoke is drawn into the flame. If it does, then you have good draft, if it doesn't then you may have a blockage in the heat exchanger or in the flue pipe.
Placing a plate over the burner is ok as long as you have proper draft. If you don't, then the plate will get hot and warp over a period of time.
SteveKJR
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas burner spark ignitor charles.gall Oven Repair (including Ranges and Cooktops) 0 04-23-2010 01:16 PM
Ignitor won't spark MarkSprat Oven Repair (including Ranges and Cooktops) 0 11-24-2009 05:35 AM
Spark ignitor problem BLKFEATHER Oven Repair (including Ranges and Cooktops) 0 03-27-2009 02:09 PM
Ignitor Wont Spark And Lit carlos p Oven Repair (including Ranges and Cooktops) 1 03-05-2008 01:40 PM
Electronic spark ignitor vornato Oven Repair (including Ranges and Cooktops) 0 12-17-2007 11:11 AM
