Discuss
lennox heater shuts off
 in
Heating, Ventilation, and Air Conditioning (HVAC)
My Lennox heater starts up fine runs for about 4 to 5 mins. then the burners shut off.Everything else stays
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » lennox heater shuts off
  #1 (permalink)
Old 01-24-2011, 12:36 PM
Junior Member
giantsfan is on a distinguished road
Default lennox heater shuts off
Model Number: G50DF{X}   Brand: -other-   Age: 5 - 10 years
My Lennox heater starts up fine runs for about 4 to 5 mins. then the burners shut off.Everything else stays running except the burners.The front panel lights up a open rollout switch which I replaced hoping that was the problem.But that did not fix it.HELP PLEASE
Ads By Google
Related Models
Frigidaire G5W
Frigidaire G7W
Maytag GA104 Washer - Top Loading
Maytag GA107 Washer - Top Loading
Maytag GA107S Washer - Top Loading
Maytag GA108 Washer - Top Loading
Maytag GA110 Washer - Top Loading
Maytag GA1110PRW Range - F/s Std Gas
Maytag GA112 Washer - Top Loading
Maytag GA180 Washer - Top Loading
Maytag GA183 Washer - Top Loading
Maytag GA190 Washer - Top Loading
Maytag GA1910 Washer - Top Loading
Maytag GA200 Washer - Top Loading
Maytag GA200S Washer - Top Loading
Maytag GA202 Washer - Top Loading
Maytag GA202S Washer - Top Loading
Maytag GA203 Washer - Top Loading
Maytag GA203S Washer - Top Loading
Maytag GA206 Washer - Top Loading
Maytag GA206S Washer - Top Loading
Maytag GA208 Washer - Top Loading
Maytag GA209 Washer - Top Loading
Maytag GA210 Washer - Top Loading
Maytag GA211 Washer - Top Loading
Maytag GA211S Washer - Top Loading
Maytag GA212 Washer - Top Loading
Maytag GA212T Washer - Top Loading
Maytag GA23CS Washer - Top Loading
Maytag GA25CM Washer - Top Loading
Maytag GA25CME Washer - Top Loading
Maytag GA25CS Washer - Top Loading
Maytag GA25CT Washer - Top Loading
Maytag GA26CD Washer - Top Loading
Maytag GA26CDC Washer - Top Loading
Maytag GA282 Washer - Top Loading
Maytag GA283 Washer - Top Loading
Maytag GA284 Washer - Top Loading
Maytag GA305 Washer - Top Loading
Maytag GA308 Washer - Top Loading
Maytag GA308S Washer - Top Loading
Maytag GA310 Washer - Top Loading
Maytag GA3110PRAM Range - F/s Std Gas
Maytag GA3110PRWM Range - F/s Std Gas
Maytag GA312 Washer - Top Loading
International GA3170MPAW Range - F/s Std Gas
International GA31713WAM Range - F/s Std Gas
International GA31713WAV Range - F/s Std Gas
International GA31713WAW Range - F/s Std Gas
International GA3171SXAW Range - F/s Cont Clean Gas
Maytag GA3177WUV Range - F/s Std Gas
Maytag GA3177WUW5 Range - F/s Std Gas
Maytag GA3216WRAM Range - F/s Std Gas
Maytag GA3216WRWM Range - F/s Std Gas
International GA3271SXAA Range - F/s Cont Clean Gas
International GA3271SXAW Range - F/s Cont Clean Gas
International GA3277WUAM Range - F/s Std Gas
International GA3277WUWM Range - F/s Std Gas
International GA3277XUA Range - F/s Std Gas
International GA3277XUAM Range - F/s Std Gas
International GA3277XUW Range - F/s Std Gas
International GA3277XUWM Range - F/s Std Gas
International GA3478XUAX Range - S/c F/s Gas
International GA3478XUWX Range - S/c F/s Gas
International GA3488VVV Range - S/c F/s Gas
International GA3510PRW Range - F/s Std Ele
International GA3531WUA Range - F/s Std Ele
International GA3531WUV Range - F/s Std Ele
International GA3531WUW Range - F/s Std Ele
Maytag GA3631XUA Range - F/s Std Ele
Maytag GA3631XUW Range - F/s Std Ele
International GA3631XUWG Range - F/s Std Ele
Maytag GA382 Washer - Top Loading
Maytag GA382T Washer - Top Loading
Maytag GA3872XUW Range - S/c F/s Ele
International GA3878XUW Range - S/c F/s Ele
Maytag GA390 Washer - Top Loading
Maytag GA3910 Washer - Top Loading
Maytag GA408 Washer - Top Loading
Maytag GA408S Washer - Top Loading
Maytag GA410 Washer - Top Loading
Maytag GA412 Washer - Top Loading
Maytag GA412T Washer - Top Loading
International GA4251WTA Range - F/s Cont Clean Gas
International GA4251WTW Range - F/s Cont Clean Gas
Maytag GA482 Washer - Top Loading
Maytag GA484 Washer - Top Loading
Maytag GA490 Washer - Top Loading
Maytag GA4910 Washer - Top Loading
Maytag GA5000 Washer - Top Loading
Maytag GA503 Washer - Top Loading
Maytag GA506 Washer - Top Loading
Maytag GA510 Washer - Top Loading
Maytag GA512 Washer - Top Loading
Maytag GA590 Washer - Top Loading
Maytag GA5910 Washer - Top Loading
Maytag GA608 Washer - Top Loading
Maytag GA608S Washer - Top Loading
Maytag GA610 Washer - Top Loading
Maytag GA612 Washer - Top Loading
Maytag GA612T Washer - Top Loading
Maytag GA613 Washer - Top Loading
Maytag GA6910 Washer - Top Loading
Maytag GA710 Washer - Top Loading
Maytag GA712 Washer - Top Loading
Maytag GA7300 Washer - Top Loading
Maytag GA7400 Washer - Top Loading
Maytag GA7500 Washer - Top Loading
Maytag GA7800 Washer - Top Loading
Maytag GA806 Washer - Top Loading
Maytag GA806S Washer - Top Loading
Maytag GA810 Washer - Top Loading
Maytag GA8100 Washer - Top Loading
Maytag GA8120 Washer - Top Loading
Maytag GA8140 Washer - Top Loading
Maytag GA8200 Washer - Top Loading
Maytag GA8210 Washer - Top Loading
Maytag GA8240 Washer - Top Loading
Maytag GA8340 Washer - Top Loading
Maytag GA8420 Washer - Top Loading
  #2 (permalink)
Old 01-24-2011, 12:38 PM
Junior Member
Default
keeps blowing air
  #3 (permalink)
Old 01-27-2011, 10:28 AM
Junior Member
SteveKJR is on a distinguished road
Default
It could be that the sensor in the heat exchanger is the problem. Some units have several heat sensors with or without a reset.
When the unit shuts down, disconnect each sensor and ohm them out before they cool down - if you get a reading across all the ones you checked then the problem is elswhere - could be in the board.
SteveKJR
Quote:
  #4 (permalink)
Old 01-27-2011, 12:41 PM
Junior Member
Default
Well come to find out what was wrong with my unit was that the installer built a box in my attic for a filter for my unit.Why they would do something so stupid is beyond me.I had to air draw to my unit come to find out so I started checking my ducts to see if the came loose or became torn by something.Come to find out when I started looking around I found the box with the filter and took it out and relocated it to a more convient place to get to change.
  #5 (permalink)
Old 01-27-2011, 01:51 PM
Junior Member
Default
So, it sounds like the high limit was doing the job - the filter caused an air flow problem by reducing airflow across the heat excahnger (that is if the filter you found was completely clogged up). As a result, the temperature in the heat exchanger exceeded the temp on the sensor and the unit shut down.
Good find. Keep an eye on those filters - they can cause problems.
SteveKJR
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lennox Heater fan/blower not kicking in luke Heating, Ventilation, and Air Conditioning (HVAC) 3 12-27-2010 10:16 PM
Electric wall heater shuts off after 1 minute MrFixItAlready! Heating, Ventilation, and Air Conditioning (HVAC) 4 11-09-2010 11:01 AM
Gas Valve On Lennox Hvac...bad??? F1RUETER Heating, Ventilation, and Air Conditioning (HVAC) 1 11-15-2009 10:07 AM
Lennox A/C starts and immediately cuts off Cooked out Heating, Ventilation, and Air Conditioning (HVAC) 1 07-20-2009 01:57 PM
lennox cttina Heating, Ventilation, and Air Conditioning (HVAC) 0 06-27-2009 11:06 AM
