| » Humidifier Question |
Model Number: Generalaire 81 Brand: -brand- Age: Less than 1 year
I have a 95% efficient Goodman furnace that is less than a year old. It has a Generalaire Model 81 drum humidifier installed on the cold air return. The humidifier drum turns when there is a call for heat. I would like to wire it so that the humidifier will work when I turn on the blower fan manually from the thermostat.
The humidifier is 24 volt and gets its power from the furnace without a transformer. One wire goes from the humidifer to the humidistat. Another from the humidisat to a pressure switch that supplies the 24 v during a call for heat. The other wire from the humidifier goes to the common terminal for thermostat connections in the bottom compartment of the furnace. I am pretty sure this is correct, but I am not looking at it at this moment. Is there any way to supply the 24 V to the humidifier when the fan is on without a call for heat??? Thanks for any help. Ads By Google Related Models |
That unit gets its power from a solid state control panel. You need to post the model number of the unit as well as the panel, as Goodman used a few different ones.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor. a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/ |
| Display Modes | |
| De-humidifier probs? | slimjim | Heating, Ventilation, and Air Conditioning (HVAC) | 4 | 05-31-2009 07:03 PM |
| May I ask a question ? | icehouse | Refrigerator & Freezer Repair | 3 | 12-15-2008 01:25 PM |
| Question | mt.top | Oven Repair (including Ranges and Cooktops) | 0 | 07-28-2008 03:03 PM |
| Question | mt.top | Oven Repair (including Ranges and Cooktops) | 0 | 07-28-2008 02:58 PM |
