Discuss
Water Heater losing performance
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I noticed that my tank water heater "Bradford White" is gradually losing the performance with the time, and about every
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Water Heater losing performance
  #1 (permalink)
Old 01-06-2011, 09:54 AM
Junior Member
vrapp is on a distinguished road
Default Water Heater losing performance
Brand: -other-   Age: More than 10 years
I noticed that my tank water heater "Bradford White" is gradually losing the performance with the time, and about every two years I have to turn the water temperature dial a little further in order to achieve the same temperature of the hot water. Seven years ago the dial was in about the middle position; now it has almost reached the limit. Does it mean that I need to start thinking about new water heater, or there's some maintenance or repair that can be done? I do drain the water about once a year, but I never replaced the anode.
Ads By Google
  #2 (permalink)
Old 01-07-2011, 10:07 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Vrapp,
I wouldn't worry about the anode, unless you're in an area with really hard water, or a lot of chemical or minerals, it has little to do with heating the water but,
You may want to remove one of the elements, and see if you have a heavy deposit of minerals attached on it,and the condition of the element.
Do you have a lot of deposits in the water when you drain the tank ?
That's about as far as I can get you, at this time.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-07-2011, 10:47 AM
Junior Member
Default
Sorry, what is "element"? I see I have forgotten to mention that this is gas water heater.
  #4 (permalink)
Old 01-07-2011, 12:09 PM
Senior Expert
Default
Vrapp,
No, You didn't mention that it was a gas heated unit,
I made the mistake of assuming.
But some or most of the information I sent you is still relavent,
You could have a sediment build up on the inside of the tank,
Instead of draining the tank, you should also flush the tank.
(Drain the tank, once empty open the water valve to allow the tank to partially drain and flush the remainder of sediment from the bottom of the tank).
The other thing you want to check is the burner flame characteristics, blue flame, little to no white or yellow tipping,and should encompass the base of the tank(not too small, not too large) and no sooting on the bottom of the tank.
Good Luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 01-07-2011, 01:31 PM
Junior Member
micoder is on a distinguished road
Default maybe just the thermostat
Maybe it is just the thermostat. If turning it up over time got you to the right temperature, they I suspect it is a thermostat going South. They are not that hard to replace.
Michael
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water overfilling/fan losing ground vinnytuco Refrigerator & Freezer Repair 0 08-05-2010 04:09 PM
water overfilling/fan losing ground vinnytuco Refrigerator & Freezer Repair 0 08-04-2010 03:58 PM
Hot Water heater Rick1 Heating, Ventilation, and Air Conditioning (HVAC) 2 02-08-2010 06:07 PM
State Water Heater - inadequate hot water shp001 Heating, Ventilation, and Air Conditioning (HVAC) 3 02-07-2010 03:31 PM
