Discuss
Furnace exhaust limit switch over heating
 in
Heating, Ventilation, and Air Conditioning (HVAC)
It's a Tappan furnace, model L1RC 080D-16B, serial #- L1D060606846. I've checked the inlet and the outlet, though both seam
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Furnace exhaust limit switch over heating
  #1 (permalink)
Old 01-05-2011, 05:44 PM
Junior Member
jmag is on a distinguished road
Default Furnace Inducer high temp limit switch keeps tripping
Brand: -brand-   Age: 1 - 5 years
I've checked the inlet and the outlet, though both seam fine. I pulled the output line and there seamed like there was a lot of condensation, though I'm not sure if that is a norm. Runs fine otherwise. I don't think the limit switch is bad-since the motor is hot to the touch. The unit did freeze up this summer while running the ac, would that cause excess water and make the motor run harder? I'm not sure were to go from here. Any ideas?
Ads By Google
  #2 (permalink)
Old 01-22-2011, 08:06 AM
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
Quote:
A complete make, model number, and serial number of the unit is necessary.
The information is extremly neccessary.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor.
a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/
  #3 (permalink)
Old 01-22-2011, 08:17 AM
Junior Member
Default
  #4 (permalink)
Old 01-22-2011, 08:36 AM
Junior Member
Default
While still under warranty, a service person came out and found a kink in the condensate line that comes out of the side (kink was from the original install). Witch caused the original over heat 3 Yrs ago. So I took apart all condinsate lines that I could track and blow/sucked them out, via air compressor/shop vac. The switch does not pop anymore, though the motor still seems hot. I looked at the "fan" there does not appear to be a pug to serve as a drain of sorts under the unit. There is an 1" x 3/4" piece of plastic that may serve as one, though I do not see any kind of release, there is a 1/8 hole in the center of the piece that I cannot quite see what it goes to, there is a mounting screw next to said piece, so I don't think it's a mount.........?????
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
power in the HI - limit switch don laansma Oven Repair (including Ranges and Cooktops) 0 05-29-2010 06:31 AM
high limit switch edee_em Oven Repair (including Ranges and Cooktops) 0 02-03-2010 01:20 PM
heater high limit reset switch chefzorba Dryer Repair 3 04-29-2009 06:03 PM
Terminal Limit Fuse on Exhaust for Dryer lhhsweb@gmail.com Dryer Repair 1 03-31-2009 03:24 PM
exhaust fan switch dmprid3@netzero.com Oven Repair (including Ranges and Cooktops) 1 07-03-2008 03:26 PM
