Discuss
Lennox Heater fan/blower not kicking in
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have a Lennox furnace. The furncae kicks up and the burners start. But after about 30 to 60 seconds,
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Lennox Heater fan/blower not kicking in
  #1 (permalink)
Old 11-24-2010, 10:00 AM
Junior Member
luke is on a distinguished road
Default Lennox Heater fan/blower not kicking in
Brand: -brand-   Age: 5 - 10 years
I have a Lennox furnace. The furncae kicks up and the burners start. But after about 30 to 60 seconds, it turns off. It seems that the blower does not kick in and hence the furnace shuts down.
Any advice on how to proceed/debug this problem? I appreciate your help on this.
Thanks,
  #2 (permalink)
Old 12-27-2010, 04:59 PM
Junior Member
joep189 is on a distinguished road
Default
Do you have a control board with a flashing led that you can see through a peephole in the cover of the unit? If so, look on the inside cover of the unit for the diagnostic code and see what it says is the problem. Let me know what it says.
  #3 (permalink)
Old 12-27-2010, 09:20 PM
Junior Member
Default
Thanks, I actually replaced the BCC3 board. Got the board for ~$100. Replacement was very easy, made sure I connected the wires to the the correct terminals and it is working now.
Thanks for the feedback.
-Luke
  #4 (permalink)
Old 12-27-2010, 10:16 PM
Junior Member
Default
Luke,
Thats good news. Probably then was a solder joint around the terminals of the large relays on that board. If you look closely you might see you could repair the board by soldering those points. If not, it was the timer chip and replacing the board was the only solution. Glad to hear its working.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fan in oven not kicking in marivet Oven Repair (including Ranges and Cooktops) 0 03-04-2010 09:34 AM
Gas Valve On Lennox Hvac...bad??? F1RUETER Heating, Ventilation, and Air Conditioning (HVAC) 1 11-15-2009 10:07 AM
Lennox A/C starts and immediately cuts off Cooked out Heating, Ventilation, and Air Conditioning (HVAC) 1 07-20-2009 01:57 PM
Fan Motor Kicking Off RJ 456MINK Heating, Ventilation, and Air Conditioning (HVAC) 0 07-15-2009 10:18 AM
lennox cttina Heating, Ventilation, and Air Conditioning (HVAC) 0 06-27-2009 11:06 AM
