Discuss
Trane xe 80 no heat
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hi, I have no heat coming from my Furnace. I have 4 flashed indicating an Open High Limit switch. I
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Trane xe 80 no heat
  #1 (permalink)
Old 11-18-2010, 03:19 PM
Junior Member
robstuff is on a distinguished road
Default Trane xe 80 no heat
Brand: -other-   Age: 5 - 10 years
I have no heat coming from my Furnace. I have 4 flashed indicating an Open High Limit switch. I replaced the switch and the burners came on briefly but the flame never kicked on. What else can cause the four flashes besides the limit switch being open?
FYI I had a similar situation last Spring when I got 4 flashes. I replaced the limit switch at that time and it seemed to solve the problem for the rest of the season.
Thanks in advance for your help.
Ads By Google
  #2 (permalink)
Old 11-18-2010, 03:55 PM
Junior Member
Poodle Head Mikey is on a distinguished road
Default is that the only limit?
Check the wiring diagram and see if maybe there is more than one limit in that circuit.
  #3 (permalink)
Old 11-18-2010, 04:30 PM
Junior Member
Default Thanks
Only one limit switch, so that's not the problem.
Could it be the flame rollout switches? Can these be reset?
  #4 (permalink)
Old 11-18-2010, 04:32 PM
Junior Member
Default
Do they have a small button to push? Right betwen the wiring terminals?
  #5 (permalink)
Old 11-21-2010, 08:16 AM
Member
whsydddy9 is on a distinguished road
Default
There is obviously more of a problem if this high limit has to be replaced annually. Roll out which trips this limit is a sign of greater problems that could be FAMILY SAFETY problems. GET AN HVAC CONTRACTOR FOR A CURE.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Trane XE90 normal call for heat nsbrew Heating, Ventilation, and Air Conditioning (HVAC) 4 10-27-2010 04:46 PM
TRANE XB80 no heat! tommyt37 Heating, Ventilation, and Air Conditioning (HVAC) 2 05-15-2010 09:07 PM
Trane furnace has no heat, fan still working slycer2002 Heating, Ventilation, and Air Conditioning (HVAC) 5 03-16-2010 07:12 AM
Is my Trane Gas/Electric overheating? gfergie Heating, Ventilation, and Air Conditioning (HVAC) 1 12-22-2008 10:12 AM
