Electric wall heater shuts off after 1 minute
Model Number: N184-A Brand: -other- Age: More than 10 years
I have a Nautilus (A Nortek Company) in-wall, electric, forced air heater that is probably more than a decade old, but I can't find any information about it at all via Google or anywhere else I've searched. The information sticker states that it is "Model Numbers" N184-A and N186-A, but searches for just the model numbers does not give any useful results either.
Regardless, the issue I have is probably not model specific. When I turn the heater on by turning the single knob, whether I set it for low, medium, or high, the heater runs for about one minute, then shuts off. The only way to get it to turn back on is to press the reset button, which indicates that an internal circuit breaker is being tripped. In addition, when I have the front cover off, I can see that only about 1/8th of the heating element is actually getting hot, but it's enough to warm up the bathroom it's installed in anyway as long as I can get it to run longer than a minute. So what is the likely cause of the internal breaker being tripped? Will I need to replace a part, and if so does anybody know where I might find parts for this unit?
Ads By Google
Related ModelsNorge N31100PAA RANGE- F/S STD GAS Norge N31100PAW RANGE- F/S STD GAS Norge N3110KRA RANGE- F/S STD GAS Norge N3110KRW RANGE- F/S STD GAS Norge N3110PPA RANGE- F/S STD GAS Norge N3110PPW RANGE- F/S STD GAS Norge N3110PRA RANGE- F/S STD GAS Norge N3110PRW RANGE- F/S STD GAS Norge N31111XAA RANGE- F/S STD GAS Norge N31111XAW RANGE- F/S STD GAS Norge N31115WAV RANGE- F/S STD GAS Norge N31115XAA RANGE- F/S STD GAS Norge N31115XAW RANGE- F/S STD GAS Norge N3120SPA RANGE- F/S STD GAS Norge N3120SPN RANGE- F/S STD GAS Norge N3120SPW RANGE- F/S STD GAS Norge N3120SRA RANGE- F/S STD GAS Norge N3120SRW RANGE- F/S STD GAS Norge N3121XPA RANGE- F/S STD GAS Norge N3121XPW RANGE- F/S STD GAS Norge N3121XRA RANGE- F/S STD GAS Norge N3121XRW RANGE- F/S STD GAS Norge N3121XTA RANGE- F/S STD GAS Norge N3121XTW RANGE- F/S STD GAS Norge N3137XRA RANGE- F/S STD GAS Norge N3137XRW RANGE- F/S STD GAS Roper N3157*0 Ranges, Electric* Roper N3157*1 Ranges, Electric* Roper N3157W0 Ranges, Electric* Roper N3157W1 Ranges, Electric* Norge N3177VUV RANGE- F/S STD GAS Norge N3177XRA RANGE- F/S STD GAS Norge N3177XRW RANGE- F/S STD GAS Norge N3177XUA RANGE- F/S STD GAS Norge N3177XUW RANGE- F/S STD GAS Roper N3257*0 Ranges, Electric* Roper N3257*1 Ranges, Electric* Roper N3257W0 Ranges, Electric* Roper N3257W1 Ranges, Electric* Roper N3357*0 Ranges, Electric* Roper N3357W0 Ranges, Electric* Norge N3422PRA RANGE- S/C F/S GAS Norge N3422PRW RANGE- S/C F/S GAS Norge N3438SRA RANGE- S/C F/S GAS Norge N3438SRW RANGE- S/C F/S GAS Norge N3438VRV RANGE- S/C F/S GAS Roper N3457*0 Ranges, Electric* Roper N3457W0 Ranges, Electric* Norge N3472SRA RANGE- S/C F/S GAS Norge N3472SRW RANGE- S/C F/S GAS Norge N3478VRV RANGE- S/C F/S GAS Norge N3478VVV RANGE- S/C F/S GAS Norge N3478XRA RANGE- S/C F/S GAS Norge N3478XRW RANGE- S/C F/S GAS Norge N3478XVA RANGE- S/C F/S GAS Norge N3478XVW RANGE- S/C F/S GAS Norge N3510KRA RANGE- F/S STD ELE Norge N3510KRW RANGE- F/S STD ELE Norge N3510PPA RANGE- F/S STD ELE Norge N3510PPW RANGE- F/S STD ELE Norge N3510PRA RANGE- F/S STD ELE Norge N3510PRW RANGE- F/S STD ELE Norge N3520SPA RANGE- F/S STD ELE Norge N3520SPN RANGE- F/S STD ELE Norge N3520SPW RANGE- F/S STD ELE Norge N3520SRA RANGE- F/S STD ELE Norge N3520SRW RANGE- F/S STD ELE Norge N3521XPA RANGE- F/S STD ELE Norge N3521XPW RANGE- F/S STD ELE Norge N3521XRA RANGE- F/S STD ELE Norge N3521XRW RANGE- F/S STD ELE Norge N3832XRA RANGE- S/C F/S ELE Norge N3832XRW RANGE- S/C F/S ELE Norge N3875XRA RANGE- S/C F/S ELE Norge N3875XRW RANGE- S/C F/S ELE Norge N3878VRV RANGE- S/C F/S ELE Norge N3878VVD RANGE- S/C F/S ELE Norge N3878VVV RANGE- S/C F/S ELE Norge N3878XRA RANGE- S/C F/S ELE Norge N3878XRW RANGE- S/C F/S ELE Norge N3878XVA RANGE- S/C F/S ELE Norge N3878XVW RANGE- S/C F/S ELE Magic Chef N40C-3-X9 MWAVE- CNTRTP / STAND ALONE Norge N4231WRA RANGE-F/S CONT CLEAN GAS Norge N4231WRW RANGE-F/S CONT CLEAN GAS Norge N4251WTA RANGE- F/S STD GAS Norge N4251WTW RANGE- F/S STD GAS Roper N9157*0 Ranges, Electric* Roper N9157*1 Ranges, Electric* Roper N9157L0 Ranges, Electric* Roper N9157L1 Ranges, Electric* Roper N9157X0 Ranges, Electric* Roper N9257*0 Ranges, Electric* Roper N9257*1 Ranges, Electric* Roper N9257*2 Ranges, Electric* Roper N9257L1 Ranges, Electric* Roper N9257L2 Ranges, Electric* Roper N9257X0 Ranges, Electric* Roper N9257X1 Ranges, Electric* Roper N9357*0 Ranges, Electric* Roper N9357*2 ELECTRIC RANGE Roper N9357*3 Ranges, Electric* Roper N9357L0 Ranges, Electric* Roper N9357L2 ELECTRIC RANGE Roper N9357L3 Ranges, Electric* Roper N9457*0 Ranges, Electric* Roper N9457*2 Ranges, Electric* Roper N9457*3 Ranges, Electric* Roper N9457*4 Ranges, Electric* Roper N9457*5 Ranges, Electric* Roper N9457L3 Ranges, Electric* Roper N9457X0 Ranges, Electric* Roper N9457X2 Ranges, Electric* Roper N9457X3 Ranges, Electric* Roper N9457X4 Ranges, Electric* Roper N9457X5 Ranges, Electric* Roper N9608*0 Ranges, Electric* Roper N9608W0 Ranges, Electric* Frigidaire NA WASHER-FRIGIDAIRE Amana NA2110 WASHER-TOP LOADING
