Discuss
Furnace runs high, AC does not
 in
Heating, Ventilation, and Air Conditioning (HVAC)
RUUD Silohette II Furnace Tappan Condensor Unit- Model FS3BA-024KA (2 Ton) Here is my current issue. Bought this home
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Furnace runs high, AC does not
  #1 (permalink)
Old 10-04-2008, 06:07 PM
fuchs1bl fuchs1bl is offline
Junior Member
fuchs1bl is on a distinguished road
Default Furnace runs high, AC does not
Brand: -other-   Age: 1 - 5 years
Bought this home 18 months ago
Newer furnace and condesor unit.
During the winter, Furnace can warm the house very quickly and efficently with a large amount of air moving thru the registers. During the summer months when we run the AC, it struggles to cool the house at all, with very little air flow from the registers.
I asked a buddy, he had me check to make sure the wiring had both Furnace and AC wires on the high speed for the blower and when i checked they were. Any suggestions on how to alliviate the problem with little air flow while using the condenser during our summer?
Brian
Need more info, ask, Im new to this forum, and not very versed in HVAC
  #2 (permalink)
Old 10-06-2008, 06:59 AM
icehouse icehouse is offline
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default Re: Fan Speed
The A/C should be wired for high speed, and the furnace should be wired low speed. If this does not help you need a fan control center.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor. Vist www.hvacbob.com
  #3 (permalink)
Old 10-06-2008, 04:43 PM
Junior Member
Default
So if the AC is currently wired on high, i take it i need a blower control?
  #4 (permalink)
Old 10-06-2008, 05:52 PM
Senior Expert
APP Volunteer
Default
No. Wire the A/C to high and furnace to low. If problem still exists change Amazon.com: Honeywell 90-113 Fan Control Center R8239A1052 Relay: Home Improvement
__________________
  #5 (permalink)
Old 10-07-2008, 05:30 AM
Senior Expert
APP Volunteer
Default
Here is the wiring information.
http://customer.honeywell.com/techli...0s/60-0583.pdf
__________________
  #6 (permalink)
Old 10-08-2008, 09:32 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
You should have a fan relay on the unit mounted on top of the fan center. The low speed is red and high is black . Common is usually purple or white. I would venture to say the wires are reversed on that fan relay.A dang Ruud ain't that complicated.
  #7 (permalink)
Old 10-09-2008, 09:18 AM
Senior Expert
APP Volunteer
Default
Quote:
To you and I no, to a DIYer yes.
__________________
  #8 (permalink)
Old 10-09-2008, 05:24 PM
Junior Member
Default
Quote:
Yes to me, but wiring is no problem for me, ill look into it.
  #9 (permalink)
Old 10-22-2008, 12:19 PM
"NO SWEAT" HEAT & AIR INC "NO SWEAT" HEAT & AIR INC is offline
Junior Member
"NO SWEAT" HEAT & AIR INC is on a distinguished road
Default Suspect, Transformer
In my experience this problem is most likely the low voltage transformer located primarily in the furnace. when the transformer is shorted the fan relay will close on hgh speed and will provide heating when called for by the thermostat but will never provide the 24 volts necesary to change the furnaces motor speed or energize the contactor for the condensing unit, thus no cooling.
  #10 (permalink)
Old 10-22-2008, 07:27 PM
Senior Expert
APP Volunteer
Default
Question ? How can the fan relay energize if the transformer is shorted ?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool electric Dryer runs on High heat Highlander Dryer Repair 2 10-01-2008 07:28 PM
Cooktop dual element only runs on HIGH heat Sevvy Oven Repair (including Ranges and Cooktops) 0 07-20-2008 03:18 PM
Hot air furnace problem. RegB Heating, Ventilation, and Air Conditioning (HVAC) 8 03-18-2008 08:52 PM
Anyone Know How To Restart Frigidaire Furnace??? frg422 General Talk 0 01-02-2008 09:34 PM
furnace no heat amati5 Heating, Ventilation, and Air Conditioning (HVAC) 0 11-28-2007 02:46 PM
