Discuss
Furnace runs high, AC does not
 in
Heating, Ventilation, and Air Conditioning (HVAC)
If the air flow is actually lower during cooling then the fan motor is getting power on a lower speed,
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Furnace runs high, AC does not
  #11 (permalink)
Old 10-26-2008, 11:43 PM
miken miken is offline
Junior Member
miken is on a distinguished road
Default air conditioning
If the air flow is actually lower during cooling then the fan motor is getting power on a lower speed, if you followed the wires back to the board unless there is a jumper between the heat and cooling terminals there is no way to supply power from both relays to the same speed , look again.
  #12 (permalink)
Old 11-21-2008, 05:58 AM
securitya8 securitya8 is offline
Junior Member
securitya8 is on a distinguished road
Default air-conditioning
Yes i agree with you as the information provided above was satisfactory and now a days air conditioning as become a compulsary need for regular life
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool electric Dryer runs on High heat Highlander Dryer Repair 2 10-01-2008 07:28 PM
Cooktop dual element only runs on HIGH heat Sevvy Oven Repair (including Ranges and Cooktops) 0 07-20-2008 03:18 PM
Hot air furnace problem. RegB Heating, Ventilation, and Air Conditioning (HVAC) 8 03-18-2008 08:52 PM
Anyone Know How To Restart Frigidaire Furnace??? frg422 General Talk 0 01-02-2008 09:34 PM
furnace no heat amati5 Heating, Ventilation, and Air Conditioning (HVAC) 0 11-28-2007 02:46 PM
