Discuss
A/C unit won't kick on
 in
Heating, Ventilation, and Air Conditioning (HVAC)
When I adjust my electric thermostat, the fan on my outdoor unit won't turn on. There is an audible click
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » A/C unit won't kick on
  #1 (permalink)
Old 09-03-2008, 04:22 AM
Junior Member
DSMarti is on a distinguished road
Unhappy A/C unit won't kick on
Brand: GE   Age: Less than 1 year
When I adjust my electric thermostat, the fan on my outdoor unit won't turn on. There is an audible click at the outside unit however, which leads me to believe it's the relay that's not getting my fan started.
I've tried manually pushing the fan and it moves without restrictions in EITHER direction. Once it begins, it continues at the same speed under it's own power.
Before I tear this thing apart (and I am hesitant to do so as I know very little about electricity or AC units) I want to make sure I am looking in the right place.
I've also taken the panel off and written down the numbers off of the relay presently there, and cannot find any matches for them online. It's a GE relay and the codes on it are: CR453CC3HLLAY and 024-27531-000
Any assistance anyone can give is most appreciated. It's still hot here in Maryland, and the wife's about to mutiny over this AC problem.
Ads By Google
Last edited by DSMarti : 09-03-2008 at 04:24 AM. Reason: The age of the unit should be 4 years, not 1.
  #2 (permalink)
Old 09-14-2008, 03:24 PM
Junior Member
ebconn is on a distinguished road
Default Might be the Cap!
It sounds like you may have a bad capacitor. The capacitor is a metal can or cylinder with terminals on one end. It should be located under a cover panel on the outside unit. If the unit uses a dual capacitor it will have three terminals on it (most common). The three terminals will be HERM, FAN, and C (stamped into the metal next to each terminal). The herm terminal is the start assist for you compressor the C is common and the FAN is the start assist for the condenser fan motor. Caps are not easy to check but they are fairly cheap, $15 to $20.
The clicking sound you hear may be the contactor (switch) that provides power to the compressor. If you are inclined to replace the cap take the following precautions. Disconnect the power to the outside unit (trip the breaker or pull the service disconnect). Discharge any stored charge in the cap by touching a screwdriver across the terminals, then go ahead and replace the cap.
Hope this helps!
  #3 (permalink)
Old 09-14-2008, 09:37 PM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
If it's less than a year old call a authorized tech to have it checked, if you haven't already voided your warranty.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #4 (permalink)
Old 09-28-2008, 08:24 AM
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
Hope this helps!
Capacitors are easily tested with an "Ohm" meter. Disconect power. Remove the leads from the terminals (mark them). Place one lead on each terminal, and watch reading. It should go up,then slowly down. If it does not move or stays up capacitor is bad.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor.
a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Washer needs a kick start palmtree Washer Repair 1 12-12-2009 06:45 PM
How do I remove the kick panel below the door of my dishwasher? juliepag Dishwasher Repair 0 08-13-2009 01:15 PM
gas won't kick on pburke Dryer Repair 4 01-10-2009 11:17 AM
compressor wont kick in wjm Refrigerator & Freezer Repair 1 10-11-2008 05:31 PM
Upright Freezer Compressor does not kick on Kaye Refrigerator & Freezer Repair 7 01-15-2008 09:43 AM
