Discuss
Loud a/c compressor
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hello, I've got a Lennox a/c unit (model# 10ACC-060-230-02) on the ground next to my
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Loud a/c compressor
  #1 (permalink)
Old 08-21-2008, 09:19 AM
jc1506 jc1506 is offline
Junior Member
jc1506 is on a distinguished road
Default Loud a/c compressor
Model Number: 10ACC-060-230-02   Brand: -other-   Age: 5 - 10 years
Hello,
I've got a Lennox a/c unit (model# 10ACC-060-230-02) on the ground next to my house. It cools fine but when it's on, the compressor makes a loud humming noise; you can hear it from a few houses down the street! Does this mean the compressor's bad or is there an adjustment that can be made? It's about 5-1/2 years old.
Thanks.
Related Models
Amana 10C2MA Room Air Conditioner
Amana 10C2MD Room Air Conditioner
Amana 10C2MT Room Air Conditioner
Amana 10C2MY Room Air Conditioner
Amana 10C5B Room Air Conditioner
Amana 10C5C Room Air Conditioner
Amana 10C5EV Room Air Conditioner
Amana 10C5EY Room Air Conditioner
Amana 10C5EZ Room Air Conditioner
Amana 10C5V Room Air Conditioner
Amana 10C5W Room Air Conditioner
Amana 10C5Y Room Air Conditioner
Amana 10C5Z Room Air Conditioner
Frigidaire 10HA101
Frigidaire 10HA102
Frigidaire 10HA10C
Amana 10M12TA Room Air Conditioner
Amana 10M52TA Room Air Conditioner
Amana 10M52TB Room Air Conditioner
Amana 10QZ22RC Room Air Conditioner
Amana 10QZ22RC1 Room Air Conditioner
Amana 10QZ22TA Room Air Conditioner
Amana 10QZ22TB Room Air Conditioner
Amana 10V2S Room Air Conditioner
Frigidaire 11-1153-00-04 Tap(v1) / Electric Oven
Frigidaire 11-1153-23-04 Tap(v2) / Electric Oven
Frigidaire 11-1153-45-04 Tap(v3) / Electric Oven
Frigidaire 11-1153-57-04 Tap(v4) / Electric Oven
Frigidaire 11-1153-66-04 Tap(v5) / Electric Oven
Frigidaire 11-1159-00-01 Tap(v1) / Wall Oven
Frigidaire 11-1159-00-02 Tap(v1) / Wall Oven
Frigidaire 11-1159-00-03 Tap(v1) / Wall Oven
Frigidaire 11-1159-00-04 Tap(v1) / Wall Oven
Frigidaire 11-1159-00-05 Tap(v1) / Wall Oven
Frigidaire 11-1553-00-04 Tap(v1) / Electric Oven
Frigidaire 11-1553-23-04 Tap(v2) / Electric Oven
Frigidaire 11-1553-45-04 Tap(v3) / Electric Oven
Frigidaire 11-1553-57-04 Tap(v4) / Electric Oven
Frigidaire 11-1553-66-04 Tap(v5) / Electric Oven
Frigidaire 11-1559-00-01 Tap(v1) / Wall Oven
Frigidaire 11-1559-00-02 Tap(v1) / Wall Oven
Frigidaire 11-1559-00-03 Tap(v1) / Wall Oven
Frigidaire 11-1559-00-04 Tap(v1) / Wall Oven
Frigidaire 11-1559-00-05 Tap(v1) / Wall Oven
Frigidaire 11-1653-00-04 Tap(v1) / Electric Oven
Frigidaire 11-1653-23-04 Tap(v2) / Electric Oven
Frigidaire 11-1653-45-04 Tap(v3) / Electric Oven
Frigidaire 11-1653-57-04 Tap(v4) / Electric Oven
Frigidaire 11-1653-66-04 Tap(v5) / Electric Oven
Frigidaire 11-1969-00-01 Tap(v1) / Wall Oven
Frigidaire 11-1969-00-02 Tap(v1) / Wall Oven
Frigidaire 11-1969-00-03 Tap(v1) / Wall Oven
Frigidaire 11-1969-00-04 Tap(v1) / Wall Oven
Frigidaire 11-1969-00-05 Tap(v1)
Frigidaire 11-2439-00-01 Tap(v1) / Wall Oven
Frigidaire 11-2439-00-02 Tap(v1) / Wall Oven
Frigidaire 11-2439-00-03 Tap(v1) / Wall Oven
Frigidaire 11-2439-00-04 Tap(v1) / Wall Oven
Frigidaire 11-2439-00-05 Tap(v1) / Wall Oven
Frigidaire 11-2969-00-01 Tap(v1) / Wall Oven
Frigidaire 11-2969-00-02 Tap(v1) / Wall Oven
Frigidaire 11-2969-00-03 Tap(v1) / Wall Oven
Frigidaire 11-2969-00-04 Tap(v1) / Wall Oven
Frigidaire 11-2969-00-05 Tap(v1) / Wall Oven
Amana 11-2C Room Air Conditioner
Amana 11-2CH Room Air Conditioner
Amana 11-2D Room Air Conditioner
Amana 11-2G Room Air Conditioner
Amana 11-2GM Room Air Conditioner
Amana 11-2J Room Air Conditioner
Amana 11-2JM Room Air Conditioner
Amana 11-2MW Room Air Conditioner
Amana 11-2N Room Air Conditioner
Amana 11-2NM Room Air Conditioner
Amana 11-3C Room Air Conditioner
Amana 11-3CH Room Air Conditioner
Amana 11-3D Room Air Conditioner
Amana 11-3DH Room Air Conditioner
Frigidaire 11-4173-00-03 Tap(v1) / Electric Range
Frigidaire 11-4369-00-01 Tap(v1) / Wall Oven
Frigidaire 11-4369-00-02 Tap(v1) / Wall Oven
Frigidaire 11-4373-00-03 Tap(v1) / Electric Range
Frigidaire 11-4969-00-01 Tap(v1) / Wall Oven
Frigidaire 11-4969-00-02 Tap(v1) / Wall Oven
Frigidaire 11-4969-00-03 Tap(v1) / Wall Oven
Frigidaire 11-4969-00-04 Tap(v1) / Wall Oven
Frigidaire 11-4969-00-05 Tap(v1) / Electric Wall Oven
Frigidaire 11-4989-00-01 Tap(v1) / Wall Oven
Frigidaire 11-4989-00-03 Tap(v1) / Wall Oven
Frigidaire 11-4989-00-04 Tap(v1) / Wall Oven
Frigidaire 11-5969-00-01 Tap(v1) / Wall Oven
Frigidaire 11-5969-00-02 Tap(v1) / Wall Oven
Frigidaire 11-5969-00-03 Tap(v1) / Wall Oven
Frigidaire 11-5969-00-04 Tap(v1) / Wall Oven
Frigidaire 11-5969-00-05 Tap(v1) / Electric Wall Oven
Amana 11-5C Room Air Conditioner
Amana 11-5CH Room Air Conditioner
Amana 11-5D Room Air Conditioner
Amana 11-5DH Room Air Conditioner
Amana 11-5G Room Air Conditioner
Amana 11-5GH Room Air Conditioner
  #2 (permalink)
Old 08-21-2008, 09:25 AM
jackmcmanus21 jackmcmanus21 is offline
Junior Member
jackmcmanus21 is on a distinguished road
Default
if it cools fine and still works well, I'm sure a minor adjustment can be made.
  #3 (permalink)
Old 08-24-2008, 01:35 AM
Mattinthebox Mattinthebox is offline
Junior Member
Mattinthebox is on a distinguished road
Default
Hey jc, like the other members said it probably just needs an adjustment.
The compressor is a sealed unit within your condensing unit outside and cannot be adjusted but what your problem sounds like is loose compressor mounts or possibly an uneven condensing unit.
Make sure the unit is not leaning in any direction, it should be sitting level on the ground.
If thats good then make sure the unit is turned off at the thermostat and then pull the fuses at the outside disconnect.
Once you are SURE the power is OFF use a 1/4 or 5/16 nut driver remove the panel that allows access to the compressor.
The compressor has four little feet with rubber isolators bolted under them. One under each of the four feet. It should be able to move slightly in all directions as long as the line-set allows.
If you find it is loose then tighten the bolts a little more snugly, don't reef down on 'em otherwise you will get a vibration that will be louder than you already have.
If there are no rubber mounts present then you might be able to find some at the hardware store. You want something comparable to what someone might put under the legs of air compressors. Something that can stand being outside year round.
If you try that and it doesn't help and the noise is that bothersome then contact a reputable hvac service company.
Btw... just so you know, some units are louder than others and it's okay if the make some noise, they don't call a trane a "train" cuz it's hard to stop... lol
Hope that helps you...
  #4 (permalink)
Old 09-26-2008, 09:51 PM
mike chaker mike chaker is offline
Junior Member
mike chaker is on a distinguished road
Default
hi make sure your a/c is level if this is not the case your compressor is over charge
  #5 (permalink)
Old 09-27-2008, 08:48 AM
icehouse icehouse is offline
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
Re-check unit there is no such model # for Lennox
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor. Vist www.hvacbob.com
  #6 (permalink)
Old 09-27-2008, 11:18 AM
refpro refpro is offline
Junior Member
refpro is on a distinguished road
Default rob
Check your airflow, if the unit is running hot the compressor
can be louder than usual. The coil may be plugged.
When was the last spring service?
  #7 (permalink)
Old 09-28-2008, 09:07 AM
Senior Expert
APP Volunteer
Default
Yes make sure the condenser coils are clean. A little foam bathroom cleaner and hose it off.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge compressor has loud buzzing noise insynco Refrigerator & Freezer Repair 3 01-09-2009 10:18 AM
compressor hot jaq1959 Refrigerator & Freezer Repair 16 08-15-2008 09:27 PM
hot compressor looking4answers Refrigerator & Freezer Repair 10 07-01-2008 11:31 AM
frig and freezer warm,clicking noisefrom compressor,compressor very hot tdot Refrigerator & Freezer Repair 4 04-02-2008 09:35 AM
How do you ohm a compressor austin12 Refrigerator & Freezer Repair 5 03-24-2008 02:43 AM
