Discuss
Thermador Range Hood
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Range Hood stopped working. Nothing, Nada when the buttons are pressed. Checked to see that control unit is getting 120v
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Thermador Range Hood
  #1 (permalink)
Old 07-17-2010, 05:53 PM
Junior Member
gholden is on a distinguished road
Question Thermador Range Hood
Brand: Thermador   Age: 1 - 5 years
Range Hood stopped working. Nothing, Nada when the buttons are pressed. Checked to see that control unit is getting 120v from the house supply, it is.
Replaced the control unit and the buttons. Still nothing.
One strange this is, when I test for current from one of the hot leads to the hood itself, there's current; 120v. Can this be the problem?
Thanks,
Ads By Google
  #2 (permalink)
Old 07-19-2010, 01:15 PM
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default
Your current test is normal and shows that your hood is properly grounded which is a good thing... There's only so much on an appliance that can go wrong and range hoods have a minimal number of parts... You've eliminated one of them by replacing the control so the next stop is the motor... With power disconnected and wires removed from the motor you can make a continuity test through the motor to check for an open winding... No continuity = open winding which means replace the motor... You didn't list a model number so I can't see a picture of this hood or it's parts so this is all assuming the motor being powered is an A/C one and not a DC one...
  #3 (permalink)
Old 07-19-2010, 01:25 PM
Junior Member
Default
Thanks for the quick reply.
The Model Number is PH48CS/01
FD# 880900014
Would a bad motor also knock out the lights?
Regards,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Range Hood Intensive Speed Broken whizwith Oven Repair (including Ranges and Cooktops) 0 10-06-2009 09:35 AM
Problem with lights on Thermador Hood blipeles Oven Repair (including Ranges and Cooktops) 0 07-07-2009 05:40 PM
Thermador Hood Light is Blinking Kitchendude Oven Repair (including Ranges and Cooktops) 0 06-01-2009 09:04 PM
