Discuss
Replacing Maytag pulley and thrust washers
 in
General Talk
A tip I got from another site will help get all the pulley thrust washers in. Tilt the washer back
Appliance Repair Forum > Appliance Repair Help > General Talk » Replacing Maytag pulley and thrust washers
  #1 (permalink)
Old 07-15-2008, 03:07 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default Replacing Maytag pulley and thrust washers
Tilt the washer back as little as possible and stick a small piece of wood and wrapped towels on top of the agitator and close the lid. Put a heavy tool box on the lid, this will push the shaft down sufficiently to allow all the new washers to go in. You can also stick a screwdriver in the shaft slot to pry it down a little further.
Also, on the Atlantis washers that fail to release the brake, pry between the pulley and washers to release the brake. A common problem with these.
Ads By Google
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer pulley access maytag stackable lse7000 lonsum1 Dryer Repair 9 11-09-2009 03:24 AM
Old Maytag Dishwasher Failed Pump STUCK PULLEY BOLT wyclef Dishwasher Repair 0 07-23-2009 10:55 AM
Lock Washers and Cushion Washers dspayne Washer Repair 5 07-13-2009 03:10 AM
Atlantis Maytag Washer -not spinning replaced thrust bearing kit nmarie@cox.net Washer Repair 3 10-23-2008 11:33 AM
Maytag dryer motor pulley jmgaley Dryer Repair 1 09-02-2008 01:45 PM
