Discuss
How to Properly Clean your Coffee Maker
 in
General Talk
Espresso Machines To clean an Espresso machine just go after these steps: 1. Remove the group handle from the espresso
Appliance Repair Forum > Appliance Repair Help > General Talk » How to Properly Clean your Coffee Maker
  #1 (permalink)
Old 06-07-2008, 05:52 AM
Junior Member
Dennis Andrews is on a distinguished road
Default How to Properly Clean your Coffee Maker
1. Remove the group handle from the espresso machine and empty the coffee puck into a rubbish bin. Rinse the group handle with warm water.
2. Pour your chosen cleaning way out into the clean basket in the group handle. With your espresso device ready to prepare, put the group handle in the espresso machine just like you were going to brew some coffee.
3. With a bowl under the group handle, start the machine and begin pulling the 'shots'.
4. Leave the machine on for about five seconds. Then stop for ten seconds, then on again for five seconds. Repeat this process another six times.
5. Now remove the group handle from the machine and rinse with warm water.
6. Revolve your machine on without the group handle in. This will fully rinse the collection itself.
Ads By Google
  #2 (permalink)
Old 11-25-2008, 09:28 PM
Junior Member
sheeva is on a distinguished road
Default
You can also use vinegar and water once (or twice if really dirty), and then water at least twice to rinse. If you do this regularly (once a month, you will never have a problem. This really helps!
__________________
|[URL="http://delonghiespressocoffeemaker.com/"]DeLonghi Coffee Maker[/URL]|
  #3 (permalink)
Old 12-15-2008, 12:42 PM
Junior Member
Bandythomas is on a distinguished road
Default
the sad thing is my first thought was bleach... but that doesn't sound to safe.. but vinegar is a good idea ...or would baking soda do the trick??
  #4 (permalink)
Old 12-16-2008, 03:11 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
DO NOT USE BLEACH. It is usually used to kill mold which you should not have. You are correct that it is dangerous, heat bleach up you get chlorine gas just a tad hard on the lungs.
DO NOT USE BAKING SODA. Would clog it up nicely. Baking soda is used as a deodorizer.
VINEGAR is used because it is weak acid, therefore it will dissolve mineral deposits in the machine. Just make sure to flush out the unit thoroughly after cleaning unless you enjoy vinegary espresso.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher does not clean and drain properly bmind Dishwasher Repair 4 05-20-2009 06:44 AM
Cuisinart DCC 2000 coffee maker gljones General Talk 4 11-28-2008 04:16 PM
