Discuss
Seeking Motor Mount for old GE Motor
 in
General Talk
I have an old GE 1/4 HP motor that the motor mounts have dry rotted on but the motor
Appliance Repair Forum > Appliance Repair Help > General Talk » Seeking Motor Mount for old GE Motor
  #1 (permalink)
Old 05-25-2008, 11:38 AM
DIY-Guy DIY-Guy is offline
Junior Member
DIY-Guy is on a distinguished road
Default Seeking Motor Mount for old GE Motor
I have an old GE 1/4 HP motor that the motor mounts have dry rotted on but the motor is running fine. I am not sure what the motor came from but it has been used for more than 20 years to power a table saw. Some specifics of the motor: Model 5KH45AB49, Frame 45A, Volt 110, Amp 4.0, Volts 60, HP 1/4, 1 Form B, RPM 1725, 40 degree C, No. 437, Motor mount split ring 2.5", Rubber mount inside Max = 2", outside = 2.5", has 4 tabs 1" wide with a gap of 1/2" between tabs, There is a groove around the middle of the mount centered and the width of the mount should be about 3/8".
If someone knows of a place that carries parts for old GE motors that would be helpful or if someone knows where this part could be purchased that would be great. Thanks for any help you can provide.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Hums... A New motor handiman43 Washer Repair 0 02-13-2008 01:36 PM
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 5 01-15-2008 10:49 AM
need to find out how to get the motor out nascar guy Dryer Repair 2 12-11-2007 02:27 AM
Wax motor not working bcanapp Washer Repair 1 12-09-2007 09:08 PM
motor switch poboy Dryer Repair 0 11-23-2007 07:13 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
