Discuss
Washer flooding fix
 in
General Talk
Had a GE washer that was flooding due to a lot of sediment in the tub blocking the water level
Appliance Repair Forum > Appliance Repair Help > General Talk » Washer flooding fix
  #1 (permalink)
Old 04-26-2008, 09:01 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default Washer flooding fix
Had a GE washer that was flooding due to a lot of sediment in the tub blocking the water level switch plastic hose. Just dumped a lot of vinegar in the tub, let it sit for a while, and blew a mouth full of water in the plastic tubing to circulate the stuff in the bottom, sure enough, it worked and cleared everything out! It now works fine.
This worked as the sediment was from cheap laundry detergent and the vinegar dissolved the stuff.
May not work for calcium or well water iron sulphides. CLR may work for this.
__________________
  #2 (permalink)
Old 04-26-2008, 09:53 AM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
That's great!
Thanks for the tip.
__________________
John Pahl
ApplianceJunk.com
ApplianceDigest.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
machine flooding out the bottom offinga Washer Repair 1 04-17-2008 08:16 PM
flooding stackable washer anja Washer Repair 1 07-19-2007 06:55 PM
