Discuss
Maytag neptune bad spin bearing check
 in
General Talk
I had a customer complain her Maytag Neptune washer would cut out during high speed spin. I checked the basket
Appliance Repair Forum > Appliance Repair Help > General Talk » Maytag neptune bad spin bearing check
  #1 (permalink)
Old 04-25-2008, 09:59 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default Maytag neptune bad spin bearing check
I had a customer complain her Maytag Neptune washer would cut out during high speed spin. I checked the basket for rough bearings, but couldn't tell. Apparently, the bearings hadn't reached the level of failure that causes a roar.
I put an amp probe on the main black input power wire to the motor control board and measured about 1 amp at low speed and over three amps near maximum speed and the motor started to overheat. This confirmed to me that the bearings where bad.
Later,I picked up the washer as junk, took it apart and confirmed bad tub bearings, so apparently my check was valid. Any comments, please.
__________________
  #2 (permalink)
Old 04-25-2008, 11:22 AM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
[SIZE=3][FONT=Times New Roman][COLOR=black]The bearings don’t necessarily need to be totally shot [/COLOR][COLOR=#333333][FONT=Verdana][/FONT][/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Times New Roman][COLOR=black]in order to cause a problem like this. They might work [/COLOR][COLOR=#333333][FONT=Verdana][/FONT][/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Times New Roman][COLOR=black]freely when removed, but when you put belt tension on the [/COLOR][COLOR=#333333][FONT=Verdana][/FONT][/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Times New Roman][COLOR=black]pulley or a load in the drum then they can bind enough [/COLOR][COLOR=#333333][FONT=Verdana][/FONT][/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Times New Roman][COLOR=black]to place an excess load on the motor. Given more time this[/COLOR][COLOR=#333333][FONT=Verdana][/FONT][/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Times New Roman][COLOR=black]would have either fried the motor or even more likely the[/COLOR][COLOR=#333333][FONT=Verdana][/FONT][/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Times New Roman][COLOR=black]motor board.[/COLOR][COLOR=#333333][FONT=Verdana][/FONT][/COLOR][/FONT][/SIZE]
[COLOR=#333333][FONT=Verdana] [/FONT][/COLOR]
[FONT=Times New Roman][SIZE=3][COLOR=#000000] [/COLOR][/SIZE][/FONT]
  #3 (permalink)
Old 04-26-2008, 08:58 AM
Senior Expert
APP Volunteer
Default
Thanks for the info Glen65, I have little experience with these washers, will help in the future.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune wont spin Stokes Washer Repair 1 06-13-2009 01:22 PM
Maytag Neptune won't spin, buzzes oilman Washer Repair 2 04-22-2008 08:18 PM
Maytag Neptune will not spin or agitate kellyjo Washer Repair 1 04-07-2008 06:08 PM
Maytag Stem Seal/Tub Bearing fabert Washer Repair 2 01-04-2008 06:38 PM
