Discuss
Maytag neptune bad spin bearing check
 in
General Talk
I had a customer complain her Maytag Neptune washer would cut out during high speed spin. I checked the basket
Appliance Repair Forum > Appliance Repair Help > General Talk » Maytag neptune bad spin bearing check
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-25-2008, 08:59 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default Maytag neptune bad spin bearing check
I had a customer complain her Maytag Neptune washer would cut out during high speed spin. I checked the basket for rough bearings, but couldn't tell. Apparently, the bearings hadn't reached the level of failure that causes a roar.
I put an amp probe on the main black input power wire to the motor control board and measured about 1 amp at low speed and over three amps near maximum speed and the motor started to overheat. This confirmed to me that the bearings where bad.
Later,I picked up the washer as junk, took it apart and confirmed bad tub bearings, so apparently my check was valid. Any comments, please.
__________________
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-25-2008, 10:22 AM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
The bearings don’t necessarily need to be totally shot
in order to cause a problem like this. They might work
freely when removed, but when you put belt tension on the
pulley or a load in the drum then they can bind enough
to place an excess load on the motor. Given more time this
would have either fried the motor or even more likely the
motor board.
  #3 (permalink)
Old 04-26-2008, 07:58 AM
Senior Expert
APP Volunteer
Default
Thanks for the info Glen65, I have little experience with these washers, will help in the future.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune won't spin, buzzes oilman Washer Repair 2 04-22-2008 07:18 PM
Maytag Neptune will not spin or agitate kellyjo Washer Repair 1 04-07-2008 05:08 PM
Maytag Stem Seal/Tub Bearing fabert Washer Repair 2 01-04-2008 05:38 PM
Maytag Neptune wont spin Stokes Washer Repair 0 12-15-2007 11:59 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
