Discuss
whirlpool fridge wiring
 in
General Talk
I am replacing the relay and overload . someone else took the parts off and now i dont know what
Appliance Repair Forum > Appliance Repair Help > General Talk » whirlpool fridge wiring
  #1 (permalink)
Old 04-21-2008, 12:47 PM
Junior Member
redhededbear is on a distinguished road
Default whirlpool fridge wiring
I am replacing the relay and overload . someone else took the parts off and now i dont know what wire goes to what can anyone help please
Ads By Google
  #2 (permalink)
Old 04-22-2008, 04:13 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You will need an ohm meter to check compressor pins. The pins form a triangle with the common pin usually on top. Measure ohms from that pin to the other two pins. The pin with higher ohms is the start pin, the other one, the run pin. The new start device pins should be labeled. Just make sure the run capacitor, if you have one, is wired between the run and start pins.
__________________
  #3 (permalink)
Old 02-23-2009, 10:45 AM
Junior Member
zkitzo is on a distinguished road
Default
hi i have the same problem can u tell me how u went and where the wires go. my email address is [email]kerriblack@dodo.com.au[/email]
  #4 (permalink)
Old 02-24-2009, 01:36 AM
Senior Expert
APP Volunteer
Default
I assume you are using a universal start device, the original factory device will just plug in the right way, impossible to plug it in wrong. If you want to use this, follow the proceedure below.
The two pins with the highest resistance will be the run and start pins and the one left over will be the common. Measure the resistance from this pin to each of the other pins. The highest resistance will be the start pin, the lowest the run pin. The wires on the start device will be labeled s for start and r for run, and c for common. The run capacitor must be wired between the run and start pins.
When you plug the refrigerator in and the compressor starts but then stops, unplug it real fast as you made a mistake and the start winding will burn up.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Please help I need wiring diagram for Whirlpool Dryer Onyxia Dryer Repair 4 09-07-2009 12:57 PM
Whirlpool fridge (bottom freezer style) top fridge shelf getting very cold dieselgg Refrigerator & Freezer Repair 5 06-19-2009 04:51 AM
Whirlpool Wiring diagram ElectricalWiz Dryer Repair 1 02-24-2009 09:24 AM
whirlpool capacitor wiring slickvic Dishwasher Repair 3 01-26-2009 03:22 PM
Need wiring diagram for GE fridge cynxlee Refrigerator & Freezer Repair 3 11-20-2008 02:10 PM
