Discuss
whirlpool fridge wiring
 in
General Talk
I am replacing the relay and overload . someone else took the parts off and now i dont know what wire
Appliance Repair Forum > Appliance Repair Help > General Talk » whirlpool fridge wiring
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-21-2008, 12:47 PM
redhededbear redhededbear is offline
Junior Member
redhededbear is on a distinguished road
Default whirlpool fridge wiring
I am replacing the relay and overload . someone else took the parts off and now i dont know what wire goes to what can anyone help please
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-22-2008, 04:13 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You will need an ohm meter to check compressor pins. The pins form a triangle with the common pin usually on top. Measure ohms from that pin to the other two pins. The pin with higher ohms is the start pin, the other one, the run pin. The new start device pins should be labeled. Just make sure the run capacitor, if you have one, is wired between the run and start pins.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wiring Diagram Whirlpool Double Oven!! Please Help! BISH Oven Repair (including Ranges and Cooktops) 1 02-18-2008 12:00 PM
Wiring Diagram Whirlpool Double Oven!! Please Help! BISH Oven Repair (including Ranges and Cooktops) 1 02-18-2008 11:59 AM
Whirlpool Fridge cycles on and off Bum Fridge Refrigerator & Freezer Repair 4 01-13-2008 07:29 PM
Kitchen Aid Fridge KSCS25FKSS00 is freezing on the fridge size shawnharper Refrigerator & Freezer Repair 0 09-03-2007 10:27 PM
Whirlpool Fridge sweaty Jac Refrigerator & Freezer Repair 0 08-29-2007 04:51 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
