Discuss
Delta Faucet
 in
General Talk
How do I remove the handle on either the hot or cold. There is no screw holding them on to
Appliance Repair Forum > Appliance Repair Help > General Talk » Delta Faucet
  #1 (permalink)
Old 01-24-2008, 06:53 AM
deviton deviton is offline
Junior Member
deviton is on a distinguished road
Default Delta Faucet
How do I remove the handle on either the hot or cold. There is no screw holding them on to the stem ? Do they unscrew or pry them up ?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-01-2008, 01:13 AM
delta delta is offline
Junior Member
delta is on a distinguished road
Default
Go to Lowes, Ace hardware, or a plumbing supply and buy the delta brand repair kit. Make sure you replace the ball also and you have the right parts for your faucet. Shut off the hot and cold water to the faucet and take it apart. You may need the allen wrench included in the kit to remove the handle. When the allen screw is loose, the handle may need some upward persuasion to come off. The round chome piece should unscrew with the help of pliers. Use a clean soft rag around the teeth to avoid scratching the chrome. Lay out the new parts on the counter and watch closely how the old ball and parts came out. Clean it up with vineager and replace the parts and put it back to together with some teflon faucet grease. What out for those springs that can get lost easily. If all else fails, read the directions that comes with the kit. Forget the aftermarket brands, a good delta brand kit and ball should run about $15.
__________________
“I don't visit my parents often because Delta Airlines won't wait in the yard while I run in.”
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
