| » Water softener dripping |
Sorry Jim. No experience with water softeners. Hopefully one of our volunteers might help.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Go To Www3.sears.com And Look Up Your Model. You Will Need To Order The Seal Kit And Rotor. You'll Need Some Silicone Grease For The Rotor Bottom On Reassembley. (the Shaft On Top Of The Rotor Is Possibley Twisted, Throws The Timing Off) A New Seal Kit And Rotor Will Solve The Problem. The Silicone Grease Will Keep The Rotor From Dragging And Twisting. Good Luck
Thanks Bentwrench!
Unfortunately, the Sears database doesn't recognize my model number. It does, however, recognize the individual part numbers (from my owner's manual) for things like the rotor itself. You wouldn't happen to have the part number for the seal kit? My owner's manual doesn't have a "kit" listed. Just the individual parts (o rings, etc.) |
OK..I hope this helps. Drop the last 0 on your model # for the sears site. (625.348550).
The seal kit # is 7129716 and the rotor is 7199232. However, the price on the Rotor is really high. You should call Sears and ask if the Rotor is a repair kit, which may include the Seal kit. When I worked for Sears on their softeners, the rotor kit included MOST of the things you need to rebuild the valve assembley.Also, re-install the flow washers at the drain elbow. They are there for ALL water systems. They are needed for proper backwash, brine flow, and rinse. |
[SIZE=3][/SIZE]
[SIZE=3]When the softener starts to regenerate it starts for 2 seconds and [B]error 3[/B] appears on digital timer and unit stops in the cycle, I unplug unit for couple of seconds replug and unit goes into the regeneration mode and completes it's full cycle correctly,[/SIZE][SIZE=3]when unit needs to regerate again say in 4-5 days this happens again.[/SIZE] [SIZE=3]Any help or comments would be appreciated. [/SIZE] [SIZE=3]Thankyou, Paul.[/SIZE] |
| Display Modes | |
| Water Dispensor Dripping | PLMSMH | Refrigerator & Freezer Repair | 4 | 11-26-2007 09:30 AM |
| water won't stop dripping | paula williams | Washer Repair | 0 | 11-22-2007 06:40 AM |
| Water softener not taking up salt | mickey | General Talk | 1 | 10-27-2007 10:36 AM |
| Water Dispenser Dripping | Carr Boy | Refrigerator & Freezer Repair | 4 | 10-13-2007 05:36 AM |
| water dispenser dripping/needs cleaning | lniederk | Refrigerator & Freezer Repair | 0 | 10-03-2007 10:19 AM |
