Discuss
Water softener dripping
 in
General Talk
Hi all. I have a Kenmore Super Capacity Genius+ water softener (model 625.3485500) I have two issues... 1) The
Appliance Repair Forum > Appliance Repair Help > General Talk » Water softener dripping
  #1 (permalink)
Old 11-29-2007, 10:44 AM
Thorzdad Thorzdad is offline
Junior Member
Thorzdad is on a distinguished road
Default Water softener dripping
Hi all.
1) The upper drain hose has developed a fairly steady slow drip. This drip occurs outside of it's recharge period.
2) It doesn't seem to use as much salt as it used to. In past years, the salt level in the tank always matched the estimated salt level on the control panel. Now, however, the control panel will indicate, for instance, salt level 3, but the salt in the tank will still be up around the 5 or 6 level. I've probed the salt for any bridges and found none. It's all salt. I haven't changed the hardness setting, either.
Some pertinent details...
-We are on a well. East-central Indiana water (hard and rusty)
-About a year ago, I had a Sears repairman out to check the softener (it didn't seem to be softening as well as it used to) He checked the rotary valve and I think he replaced an o-ring. At that time, he also took out the two small flow plugs from the nozzle assembly. He claimed that the plugs were more for city systems that had higher pressures than well systems.
-Also, about a year ago, I cleaned-out the salt tank.
Any suggestions as to what i should be looking at will be appreciated.
Thanks,
Jim
(I wasn't sure where a water softener post would go. Mods, please feel free to move this to the appropriate forum)
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-03-2007, 11:04 AM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Sorry Jim. No experience with water softeners. Hopefully one of our volunteers might help.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-14-2007, 03:53 PM
bentwrench1999 bentwrench1999 is offline
Senior Expert
APP Volunteer
bentwrench1999 is on a distinguished road
Default Water Softener Problem
Go To Www3.sears.com And Look Up Your Model. You Will Need To Order The Seal Kit And Rotor. You'll Need Some Silicone Grease For The Rotor Bottom On Reassembley. (the Shaft On Top Of The Rotor Is Possibley Twisted, Throws The Timing Off) A New Seal Kit And Rotor Will Solve The Problem. The Silicone Grease Will Keep The Rotor From Dragging And Twisting. Good Luck
  #4 (permalink)
Old 12-15-2007, 06:02 AM
Junior Member
Default
Thanks Bentwrench!
Unfortunately, the Sears database doesn't recognize my model number. It does, however, recognize the individual part numbers (from my owner's manual) for things like the rotor itself. You wouldn't happen to have the part number for the seal kit? My owner's manual doesn't have a "kit" listed. Just the individual parts (o rings, etc.)
  #5 (permalink)
Old 12-15-2007, 07:52 PM
Senior Expert
APP Volunteer
Default Water Softener Part #'s
OK..I hope this helps. Drop the last 0 on your model # for the sears site. (625.348550).
The seal kit # is 7129716 and the rotor is 7199232.
However, the price on the Rotor is really high. You should call Sears and ask if the Rotor is a repair kit, which may include the Seal kit. When I worked for Sears on their softeners, the rotor kit included MOST of the things you need to rebuild the valve assembley.Also, re-install the flow washers at the drain elbow. They are there for ALL water systems. They are needed for proper backwash, brine flow, and rinse. Let me know if all works out ok.. wrench
  #6 (permalink)
Old 01-08-2008, 09:30 AM
Senior Expert
APP Volunteer
Question Water softener dripping
Hey Jim, just a quick note to see if you got your water softener back up and running. Let me know, Mike..aka wrench
__________________
  #7 (permalink)
Old 03-14-2008, 08:36 AM
atfab atfab is offline
Junior Member
atfab is on a distinguished road
Default Kenmore Super 8 water softener.
When the softener starts to regenerate it starts for 2 seconds and error 3 appears on digital timer and unit stops in the cycle, I unplug unit for couple of seconds replug and unit goes into the regeneration mode and completes it's full cycle correctly,when unit needs to regerate again say in 4-5 days this happens again.
Any help or comments would be appreciated.
Thankyou, Paul.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Dispensor Dripping PLMSMH Refrigerator & Freezer Repair 4 11-26-2007 09:30 AM
water won't stop dripping paula williams Washer Repair 0 11-22-2007 06:40 AM
Water softener not taking up salt mickey General Talk 1 10-27-2007 10:36 AM
Water Dispenser Dripping Carr Boy Refrigerator & Freezer Repair 4 10-13-2007 05:36 AM
water dispenser dripping/needs cleaning lniederk Refrigerator & Freezer Repair 0 10-03-2007 10:19 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
