Discuss
Crosley compressor Wiring
 in
General Talk
I have a crosley refrigerator Model CT19B6f that we moved, when doing so the starter and overload came off the
Appliance Repair Forum > Appliance Repair Help > General Talk » Crosley compressor Wiring
  #1 (permalink)
Old 02-26-2009, 03:57 PM
Junior Member
scottmiles is on a distinguished road
Default Crosley compressor Wiring
I have a crosley refrigerator Model CT19B6f that we moved, when doing so the starter and overload came off the compressor. I would like to re-attach them correctly and am not sure how to do it. There are 3 pins on the side of the compressor and it looks as though the starter connects to the bottom two and the overload to the top pin. There is also a flat connector on the overload as well as on the compressor, should there also be a wire to connect those that we may have lost or do I have all I need?
Scott
Ads By Google
  #2 (permalink)
Old 02-27-2009, 04:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
[QUOTE=scottmiles;65722]...[B]1.[/B] There are 3 pins on the side of the compressor and it looks as though the starter connects to the bottom two and the overload to the top pin...
...[B]2.[/B] There is also a flat connector on the overload as well as on the compressor...[/QUOTE]
Hi Scott,
1. You are absolutely right.
2. The "flat" connector on the overload should be connected to the Blue wire (incoming hot wire). The "flat" connector on the compressor is probably the ground and it is not necessary to connect it.
Here are the break down and the wiring diagram for the Crosley refrigerator [url=http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=661739&&model_id=47783]Model CT19B6FQ[/url]
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-02-2009, 11:36 AM
Junior Member
Default
[QUOTE=Gene;65992]Hi Scott,
Gene.[/QUOTE]
Thanks Gene for taking the time to help, that solves my problem.
Scott Miles
  #4 (permalink)
Old 03-02-2009, 03:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn air wiring cooktop dwndrft wiring Q Pat_repairingstuff Oven Repair (including Ranges and Cooktops) 0 11-23-2009 04:27 PM
freezer warm, clicking noise from compressor, compressor very hot sgtmajor58 Refrigerator & Freezer Repair 1 08-08-2009 06:57 PM
Crosley upright freezer. Compressor jd5555 Refrigerator & Freezer Repair 1 11-14-2008 09:40 AM
frig and freezer warm,clicking noisefrom compressor,compressor very hot tdot Refrigerator & Freezer Repair 4 04-02-2008 08:35 AM
