Discuss
Fridge in Garage
 in
General Talk
My garage fridge/freezer is not keeping the freezer part cold enough. I am aware of the problem with fridges in
Appliance Repair Forum > Appliance Repair Help > General Talk » Fridge in Garage
  #1 (permalink)
Old 01-31-2009, 09:46 AM
Junior Member
giannit is on a distinguished road
Default Fridge in Garage
My garage fridge/freezer is not keeping the freezer part cold enough. I am aware of the problem with fridges in cold spaces so I turned up the freezer compartment to max and it still won't keep an ice cube solid. So here are my questions:
1) Am I damaging my fridge by keeping it on? The fridge section seems to stay cold enough.
2) If I want to use the heat of a very low watt incandescant bulb (<15W) to fool the fridge into working...where would I put it? Near the exhaust?
Ads By Google
  #2 (permalink)
Old 01-31-2009, 12:11 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
[COLOR=Blue]1) Am I damaging my fridge by keeping it on?[/COLOR]
Depends what temp the garage drops down to.
If you get too far below freezing you are not doing it any good.
Compressor has oil in it which thickens with the cold and can make the compressor work harder to get started.
[COLOR=Blue]The fridge section seems to stay cold enough.[/COLOR]
Your problem is the defrost. The defrost heater comes on putting heat in the freezer section but due to the ambient temp the fridge does not come on after defrost so the heat melts your food.
[COLOR=Blue]2) If I want to use the heat of a very low watt incandescant bulb (<15W) to fool the fridge into working...where would I put it? Near the exhaust?[/COLOR]
Up close to where the end of your thermostat capillary is
Problem is you will have to check the bulb regularly. If it burns out you are back to your original problem. Might be better off with 2 small ones. You may have to move it around as you are trying to do a balancing act between the bulb's heat and the fridge's set temp.
__________________
  #3 (permalink)
Old 01-31-2009, 01:58 PM
Junior Member
Default
Thanks denman. I will try to find out where the thermostat capillary is located. Don't know how successful I will be. The unit is a new Kenmore and the exhaust is at the bottom. Can you direct me?
  #4 (permalink)
Old 01-31-2009, 02:54 PM
Senior Expert
APP Volunteer
Default
Cannot really help but get your Model Number and go to the Sears or Kenmore site. Go to the customer service area and see if you can download a parts breakdown for this unit (sometimes is in the manuals section).
You may have to sign up for Manage My Home site which seems to be down as much as it is up and running.
Kenmore's are a pain to get any useful info on re: wiring diagrams, parts layouts etc.
If you do not have a wiring diagram for it, take a look behind the kick plate they may have hidden it there. May even be taped under the drip tray.
If the unit is thermistor/ PC board controlled it may be difficult to do this mod.
__________________
  #5 (permalink)
Old 02-01-2009, 02:03 PM
Junior Member
Default
I found the manual on a Frigidaire site. The link is:
[URL]http://www.frigidaire.com/support/ResultsPage.asp?strModel=970&User=&Search=Search[/URL]
It's actually a Frigidaire model 970-419120 private labelled Kenmore for Sears.
Anyway, neither the user manual or parts manual show me where the thermostat capillary is found.
If you can figure out where it might be from this I would certainly appreciate it.
  #6 (permalink)
Old 02-01-2009, 02:57 PM
Senior Expert
APP Volunteer
Default
Thermostat looks like it is mounted under the cover on the top of the fresh food compartment.
Looks like the capillary goes to the rear of the unit where there is the vent which connects the freezer to the fresh food. May go up through this vent.
__________________
  #7 (permalink)
Old 02-02-2009, 06:11 AM
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
Frigidaire makes a special thermostat heater.
[url=http://frigidaire.stores.yahoo.net/gakithecokit.html]Frigidaire - Garage Refrigerator Heater Kit[/url]
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor.
a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Refrigerator Garage Kit Part# squier3 Refrigerator & Freezer Repair 1 01-28-2010 05:45 AM
Garage fridge trips GFI tomking Refrigerator & Freezer Repair 4 12-21-2009 05:46 AM
Fridge won't work in cold garage.h dcrone9 Refrigerator & Freezer Repair 2 04-02-2009 06:50 PM
