Discuss
ge side by side problem with icemaker
 in
General Talk
The ice maker is making ice but is not dispensing. the water dispenser works. Any ideas? Ads By Google
Appliance Repair Forum > Appliance Repair Help > General Talk » ge side by side problem with icemaker
  #1 (permalink)
Old 01-16-2009, 05:22 AM
Junior Member
machowski is on a distinguished road
Default ge side by side problem with icemaker
Ads By Google
  #2 (permalink)
Old 01-17-2009, 09:45 AM
Junior Member
virgilio is on a distinguished road
Default GE Model#TFX20JRBB WW
Icemaker Not Working But Water Dispenser Ok
  #3 (permalink)
Old 01-21-2009, 12:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
machowski,
Does the ice maker release ice cubes into the ice bin?
Did you hear any noise when you pushed the ice release lever on the dispenser?
What is the complete model number of the refrigerator?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #4 (permalink)
Old 01-21-2009, 12:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
virgilio,
Check the water feeding tube into the ice maker for a clog and/or frost. If there is a green LED on the ice maker does it blink or it stays "on"?
__________________
  #5 (permalink)
Old 03-01-2009, 07:56 PM
Junior Member
vincenzo333 is on a distinguished road
Default Icemaker not working
Hi Gene. I was wondering about the outcome of this question. I have a similar issue. GE, side-by-side fridge, model #GSH25JSTA SS. The icemaker does not make ice. Water dispenser is fine. I changed the filter, but that didn't do it. Green light just blinks. Any ideas would be appreciated. Thanks.
Vincenzo
  #6 (permalink)
Old 03-02-2009, 01:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the ice maker green LED light blinks then the ice maker is bad and has to be replaced.
- The part number for the ice maker is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=4345120&&model_id=5236645&diagram_id=24926528"]AP4345120[/URL]
Here are the break down diagrams for the GE refrigerator [url=http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=24926528&&model_id=5236645]Model GSH25JSTASS[/url]
__________________
  #7 (permalink)
Old 03-02-2009, 03:13 PM
Junior Member
Default
Thanks Gene.
Is this part fairly easy to install? Or would I be best served to call a GE service tech?
  #8 (permalink)
Old 03-02-2009, 04:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This part is very simple to replace. Remove the ice bin. Remove the top shelf and the two screws holding the ice maker. Unplug the wire harness and install the new one in the reversed order. I believe the new ice maker comes with the instructions.
__________________
  #9 (permalink)
Old 03-04-2009, 07:16 PM
Junior Member
Default
Gene, you're not going to believe it, but I ordered the part -- then plugged the refrigerator back in (because I had the idea that maybe the line to the icemaker was frozen, so I'd been letting it thaw for several hours). A half hour later, I hear ice dropping into the tray. Murphy's Law.
I'm not sure if thawing solved it, but the light is no longer blinking and I've got ice. I put the ordered part on "hold" and I'll see if the icemaker continues without issue.
Thought you might like to know about it. Blinking green light isn't necessarily fatal (knocks on wooden desk). I'll be sure to let you know if this changes.
Thanks again for the help.
  #10 (permalink)
Old 03-05-2009, 10:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I wish it's gone, but ....
Keep us posted.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Side-by-side, icemaker not working, water dispenses fine SteffiL Refrigerator & Freezer Repair 0 09-09-2009 03:52 PM
Side-by-Side Freezer Icemaker Flap Vinnie the Repairman Refrigerator & Freezer Repair 4 06-11-2009 08:48 AM
Kenmore Side by Side Icemaker quit working now overflows jcsophie Refrigerator & Freezer Repair 0 01-02-2009 06:25 PM
Kenmore side by side icemaker over fills mdg224 Refrigerator & Freezer Repair 1 01-01-2009 08:11 AM
whirlpool refrigerator side by side icemaker makes little or no ice T-ROY Refrigerator & Freezer Repair 1 11-07-2008 01:37 PM
