| » Extension Cord Problem? |
One of the problem can be [B][URL="http://www.hometips.com/repair-fix/outlet-reverse-polarity.html"]reversed polarity[/URL][/B] at the outlet. Most of an electronic operated appliances are very sensitive to such condition.
Also not all appliances can be used with an extension cord. You have to read the Owners manual. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
It depends upon the amperage draw of the appliance. If this isn't stated, look for a wattage rating. Watts equal volts x amps. A light duty cord will heat up from a high amperage draw and cause a fire! Do NOT use appliances on that cord. They make special heavy duty appliance cords but you still have to run the calculations. You also need to know what amperage rating the breaker/ fuse has for that circuit. That means tracing the circuit back to the distribution panel. You could also have improper wiring so again, you really need an electrician in there. Talk to the landlord. If he balks, talk to the Fire Marshal. He'll force them to get it fixed.
Current codes call for two 20 ampere ground fault protected appliance circuits in the kitchen separate from the refrig., lighting and other appliances. See what you can do about getting an electrician in there before someone dies in a fire. HTH, Hearthman
__________________
Keep the fire in the fireplace. |
Crock Pot
Check that the pot's line cord does not show any signs of overheating/melt. Also if the plug's prongs are dirty/arced clean them up with some fine emery cloth. Put some water in it and plug it into an outlet directly. If it runs OK and does not start generating the burnt smell, it is probably OK. The burnt smell does linger for a long time. Your extension cord is dependent on two things Wire size - look for an extension with 14 gauge wire. 12 if you can find one but this may take some searching, The higher the number the smaller the wire. Length - use the shortest one that will reach.
__________________
| Display Modes | |
| Cord replacement | davewest | Oven Repair (including Ranges and Cooktops) | 2 | 10-20-2009 11:28 AM |
| Power cord | gina39 | Dryer Repair | 2 | 06-07-2009 08:30 PM |
| Whrilpool Extension Hose | Torwadeo | Washer Repair | 2 | 10-15-2008 10:07 PM |
| Plugged washer into generator with extension cord | bondikovacs | Washer Repair | 3 | 09-19-2008 01:23 PM |
| Power cord | james188 | Oven Repair (including Ranges and Cooktops) | 1 | 12-22-2007 09:24 PM |
