Discuss
Propane pilot light problem
 in
General Talk
I have a free-standing propane stove. Sometimes when I turn the thermostat up (when the stove is off) the pilot
Appliance Repair Forum > Appliance Repair Help > General Talk » Propane pilot light problem
  #1 (permalink)
Old 01-12-2009, 02:04 PM
Junior Member
jcapaci is on a distinguished road
Default Propane pilot light problem
I have a free-standing propane stove. Sometimes when I turn the thermostat up (when the stove is off) the pilot will go out.
At other times the burner simply wont light, although the pilot is still lit.
Or the burner wont light even though the ambient temperature is less than the thermostat setting. (and the pilot is still lit)
At other times it works fine.
With regard to problem number two, it has been suggested the wires from the stove are too small. The distance from stove to thermostat is approximately 25 feet. I'm guessing the wire is about 24 gauge.
Could the two problems be related? Or do I have two separate issues?
Ads By Google
  #2 (permalink)
Old 01-13-2009, 02:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
[QUOTE=jcapaci;56140]...The distance from stove to thermostat is approximately [B][U]25 feet[/U][/B]...[/QUOTE]
What kind of stove is it? Sounds like this is a heater? What is the complete model number?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-13-2009, 02:55 PM
Junior Member
Default
Hi Gene,
It is a heater-it is a Brass Flame model BF 40
The controller on the back has a label with the following info:
Robertshaw-Grayson
7000MVRB - 4 - LC
758-716-441 Max 1/2 PSI
Lo 1.3 - Hi 3.5
For Use With Millivolt System Only
9530 Assembled in Mexico
Thanks for your help,
John
  #4 (permalink)
Old 01-13-2009, 02:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
John,
Unfortunately I'm not familiar with HVAC. Maybe somebody else on the forum can help you better.
__________________
  #5 (permalink)
Old 01-13-2009, 08:38 PM
Fireplace Expert
APP Volunteer
Hearthman is on a distinguished road
Exclamation
This sounds like a 700mv thermopile powered valve. You could have low inlet gas pressure, dirty pilot orifice, undersized gas piping, weak EPU in the valve or just a tired thermopile. Takes comprehensive troubleshooting. If you are not a pro, hire one. If you are a pro, you will need a set of gas pressures for inlet static pressure, inlet burning pressure with entire house under full load, manifold pressure, valve Ohms on EPU and main operator, WSK Ohms, millivolt readings btw contacts, open circuit mv on thermopile, closed circuit on main operator,
Your other problem is you say this is LP but the numbers you read off the valve are for NG. Has this valve been converted to LP? Usually 10.0 wci manifold LP.
Wall switch wiring should be at least 18gauge with good clean, firm contacts and a few joints as possible. Switch should be high quality low resistance type with gold plating on contacts.
HTH,
Hearthman
__________________
Keep the fire in the fireplace.
  #6 (permalink)
Old 01-22-2009, 02:11 PM
Junior Member
Default
Thanks for the help. The reason I posted this problem is that I did hire a professional.
And the stove was supposedly converted to LP about five years back.
He changed the thermopile.
He changed the main valve.
He installed larger piping to the tank.
He cleaned the pilot orifice.
He probably did other things as well because he visited us about six times.
After each visit the way we would test the stove was to use it for a while to see if the most recent fix actually fixed it. Eventually the stove appeared to be working; I asked him what he did that made it work. He said he wasn't sure.
Worked fine for about a year, then began acting up again. Most recently it has taken to turning off while the main burner is on. Both the main burner and the pilot simply shut down after about fifteen minutes of operation. In addition to the other problems.
Almost sounds as though there is a short in the main operator-or maybe the thermopile is bad?
  #7 (permalink)
Old 01-22-2009, 04:55 PM
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
From Honeywell Controls : Q335 Thermocouple is a quick dropout thermocouple used in
conjunction with the Q313 Thermopile Generator in the Q382
Pilot Burner. The flame in the pilot burner is directed toward
the thermocouple and the thermopile. As long as pilot flame is
present, the millivolt output from the thermocouple keeps the
safety valve in the gas control open, allowing the main gas to
flow to the appliance on demand. The millivolt output from the
thermopile energizes the operator in the valve on demand.
Q313 Thermopile Generator contains multiple thermocouples
connected in series to increase the millivoltage output. The
power generated is sufficient to operate an automatic millivolt
gas control system, independent of any outside power
source. Don't know if this helps.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor.
a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/
  #8 (permalink)
Old 01-22-2009, 05:03 PM
Senior Expert
APP Volunteer
Default
From Robertshaw :
__________________
  #9 (permalink)
Old 01-22-2009, 06:12 PM
Junior Member
williamsce is on a distinguished road
Default
check thermo couple or gas pressure coming into the valve
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
propane pilot lights londonlady55 Oven Repair (including Ranges and Cooktops) 0 11-29-2009 07:00 PM
BUCK Propane fireplace pilot light ncord51 Heating, Ventilation, and Air Conditioning (HVAC) 3 11-16-2009 07:25 AM
rv norcold won't light W/ propane highsierra Refrigerator & Freezer Repair 0 09-13-2009 04:33 PM
broiler won't light pilot light burns copolit Oven Repair (including Ranges and Cooktops) 3 11-19-2008 10:10 PM
magic chef propane oven won't light (has pilot light) A and J Oven Repair (including Ranges and Cooktops) 3 09-19-2008 12:36 PM
