Discuss
Water softener not taking up salt
 in
General Talk
Hi, I got such great help from this site with my fridge I thought I'd try to see what
Appliance Repair Forum > Appliance Repair Help > General Talk » Water softener not taking up salt
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-27-2007, 05:29 AM
mickey mickey is offline
Junior Member
mickey is on a distinguished road
Question Water softener not taking up salt
Hi, I got such great help from this site with my fridge I thought I'd try to see what might be wrong with my water softener before I call for service. First I should tell you I have no idea how a softener works, I just know how I feel when it doesn't. There is plenty of salt in that tank but no water, I used to see water at the bottom of that tank when the salt ran low. It is still cycling through and discharging a bunch of water but my water is NOT soft and it stinks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-27-2007, 09:36 AM
fixxit fixxit is offline
Senior Expert
APP Volunteer
fixxit is on a distinguished road
Default
would be a bit easier with a modle # which is under the lid, but, Here goes. the first this to do would be to put the softener into by-pass, this is done at the back of the softener. its a push pull set up if it a relativly new. if older it is usualy a set of valves. next check the venturi. this is located under the cap behind the lid. it is usualy located to the left of the main valve body. unscrew the cap and look for sand, rust ect.. the ventury has a break down usualy on the underside of the cover to the salt tank. as you pull it appart watch the way everythig goes. a flipped seal or flow control plug can make this fail to work properly. the venturi breaks apart in this order, Top screen, top o-ring retainer ring and o-ring, flow control plug plate with flow control plug ( note plate has center stem and the stem goes up. flow control plug, this is directional as well, concave side down) check the flow control plug for sand or grit blocking it in the center. pull the flow control plate and check the seal under it. look for cracks or any gumm. your particular modle may have a secondary flow control plug under the seal check this one for clogging or being flipped as well (concave down). i have found a kitchen sink (with strainer in to pervent loosing any small parts down the drain) the best cleaning area. put every thing back in as they cam out, put the by-pass valve back out of bypass mode. and run a manual cycle by pressing the recharge/regen button and holding it untill it begins to cycle. you can manualy advance the cycles and if you have any leaks, use the bypass.
good luck and let us know if this fixes your problem
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fabric Softener Dispenser Pam Denny Washer Repair 2 03-06-2008 08:59 AM
dryer taking to long to dry pjjj5859 Dryer Repair 1 09-28-2007 01:54 AM
frigidaire crown series taking too long to dry angryhousewife34 Dryer Repair 1 08-30-2007 12:45 AM
Dryer taking too long to dry lorrainemc Dryer Repair 2 08-20-2007 09:58 AM
Taking dryer panel off debmin Dryer Repair 1 07-26-2007 08:34 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
