Discuss
Maytag washer filled then stopped.
 in
General Talk
Maytag washer filled then stopped. LAT9824AAE. There is power to the unit (red cycle indicator lights work when dial is
Appliance Repair Forum > Appliance Repair Help > General Talk » Maytag washer filled then stopped.
  #1 (permalink)
Old 12-04-2008, 11:31 AM
Matti Matti is offline
Junior Member
Matti is on a distinguished road
Question Maytag washer filled then stopped.
Maytag washer filled then stopped. LAT9824AAE. There is power to the unit (red cycle indicator lights work when dial is rotated). Water in tub. Any dignostics, etc.? (or is it time for a new Maytag?) Appreciate guidance.....
  #2 (permalink)
Old 12-04-2008, 12:12 PM
magician59 magician59 is offline
Senior Expert
APP Volunteer
magician59 is on a distinguished road
Default
I would start by checking the lid switch.
__________________
Nemo malus felix
  #3 (permalink)
Old 12-04-2008, 12:46 PM
Junior Member
Default
[QUOTE=magician59;48083]I would start by checking the lid switch.[/QUOTE]
How?
(Don't know if this makes a difference: The unit had started and filled, then stopped.)
Thanx
  #4 (permalink)
Old 12-04-2008, 01:48 PM
Senior Expert
APP Volunteer
Default
The lid switch assembly is located inside the console. It consists of two micro switches and a fuse. You can do a continuity check on each component. If any of the three is bad, it is generally recommended that you replace the entire assembly.
__________________
Nemo malus felix
  #5 (permalink)
Old 12-05-2008, 12:05 PM
Junior Member
Default
Used a Continuity Tester:
- fuse indicated continuity both manual inspection and via tester
- black microswitch showed continuity red-black with lid down, and none when lid was open
- white microswitch showed continuity yellow-red, but not yellow-white and not white-red. Lid position made no difference.
Please do your magic and translate the above. I don't know if all terminal points tested should have shown continuity, or these results show the white microswitch is bad?
What next? (gonna run out of cean clothes real soon :-)
Thanx a 'load'.
I realized that I posted this thread in the General Talk, not in the Washer Repair. If it should be relocated, please free to do so. Sorry about that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Totally Stopped Runninglights Dryer Repair 3 09-10-2008 03:52 PM
My MAYTAG stopped working after 16 months jhoudek Dryer Repair 0 03-29-2008 01:32 PM
Filled will not go to cycle Csugarbrown9122 Washer Repair 1 01-23-2008 04:39 AM
Maytag washer stopped mid wash Brian Washer Repair 3 12-19-2007 02:03 PM
maytag ice maker stopped working Cope Refrigerator & Freezer Repair 0 10-30-2007 05:45 PM
