Discuss
Kitchen Aid blender
 in
General Talk
How do I remove the old worn out drive coupling from the base to replace it , I cannot see any
Appliance Repair Forum > Appliance Repair Help > General Talk » Kitchen Aid blender
  #1 (permalink)
Old 12-03-2008, 03:01 PM
DONOVAN DONOVAN is offline
Junior Member
DONOVAN is on a distinguished road
Default Kitchen Aid blender
How do I remove the old worn out drive coupling from the base to replace it , I cannot see any exposed fasteners that would allow me to open up the base.
  #2 (permalink)
Old 02-07-2009, 01:39 PM
Liguori Liguori is offline
Junior Member
Liguori is on a distinguished road
Default
[SIZE=3][COLOR=#000000][FONT=Times New Roman][B]Instruction Sheet for [/B][B]KitchenAid Blender Coupling Drive[/B][B] Installation[/B][/FONT][/COLOR][/SIZE]
[B][FONT=Times New Roman][SIZE=3][COLOR=#000000] [/COLOR][/SIZE][/FONT][/B]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]1)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]Unplug Blender[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]2)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]With blender facing you, insert flat blade screwdriver (3/8 to 7/16 inch) between the black coupling drive and the blender housing.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]3)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]Raise up on the screwdriver to turn the coupling drive clockwise (it is a left hand thread so the coupler keeps tight during use). Keep making ¼ turns until the coupling drive comes off. Do not worry about bending the old coupling drive. You are going to throw it away.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]4)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]There is a flat spot on the blender shaft and construction of a flat tool is possible, but not necessary.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]5)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]Check the threads on the blender shaft and clean the old metal shavings from the threads. Hand tighten the new coupling drive. It will be kept tight during normal use due to the left hand thread design and the clockwise spinning of the blades.[/COLOR][/SIZE][/FONT]
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen AId Blender DougDimond General Talk 1 02-07-2009 01:40 PM
Kitchenaid Blender coupling drive jbarker General Talk 6 02-01-2009 08:01 AM
Coupling Drive for Kitchen Aid blender Mgordon General Talk 1 12-13-2008 02:24 PM
Philips Food processor HR 7805/a - replace blender cog at top martin131 General Talk 0 04-06-2008 09:25 AM
Oster blender switch paul1968 General Talk 0 10-31-2007 07:11 AM
