Discuss
kitchenaid trash compactor model #kcs100b
 in
General Talk
Need kitchenaid part #B-113832 or #B-105437 (interlock bypass switch)for above model. Can you help? Jack Wollam [EMAIL="kewsgarden@sbcglobal.net"]kewsgarden@sbcglobal.net[/EMAIL] Ads By Google
Appliance Repair Forum > Appliance Repair Help > General Talk » kitchenaid trash compactor model #kcs100b
  #1 (permalink)
Old 09-18-2008, 06:04 AM
Junior Member
kewsgarden is on a distinguished road
Question kitchenaid trash compactor model #kcs100b
Can you help?
Jack Wollam
Ads By Google
  #2 (permalink)
Old 09-18-2008, 04:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jack,
The switch with the part number B-113832 has been discontinued by the manufacturer and is no longer available.
The switch with the part number B-105437 is Appliance Parts Pros item number [URL="http://www.appliancepartspros.com/part_details.aspx?part_id=3124207"]AP3124207[/URL] and you can buy it for $14.11
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 09-19-2008, 05:31 AM
Junior Member
Default KCS100B-Part#AP3124207
Gene:
Thanks so much for the info on above. I have been all over trying to get
this switch.
Just for your info:
I notice on many other forum inquirys on the Kitchenaid KCS 100B Trash
Compactors with complaints such as:
1. "Compactor runs continously"
2. "Compactor starts and then stops-unable to open drawer-plunger
is blocking it"
These complaints are almost always caused by the failure of the above
interlock switches. There are actually two of them. One is on the upper ram and the other is on the inner left drawer frame. They are interchangeable and identical even though they have different part #s!(spring loaded normal open, momentary closed) If the drawer frame switch fails, the compactor will not operate (drawer closed), or the compactor
will operate and crush the drawer if it is open. If the upper ram switch fails the plunger will extend partially into the drawer and stop- blocking
the drawer and the switches can not be reached for replacement
with out removing the entire compactor jacket. I have installed a bypass
switch for the upper ram switch, which will retract the plunger and then
both switches can be reached for replacement by simply removing the
upper door panel area without removing the entire compactor jacket.
These switches do fail from time to time as they do take abuse.
I hope this information will be helpfull to you with other complaints.
Thanks again for you help.
Jack
  #4 (permalink)
Old 09-19-2008, 10:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jack,
Thank you for this information. It will definitely help other people to solve such problems.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen aid trash compactor model no.KUCS02FRSS1 jfaris Trash Compactor Repair 2 02-14-2009 08:49 AM
KitchenAid Trash Compactor foot pedal wont' open the compactor Tony Seaton Trash Compactor Repair 1 08-19-2008 12:03 AM
kitchenaid KCS100B compactor daved Trash Compactor Repair 0 04-13-2008 04:27 PM
Model Tu4100xtp2 Whirlpool Trash Compactor Al Ojeda Trash Compactor Repair 1 02-19-2008 12:38 PM
Whirlpool Trash Compactor --Model #TC900QPDQ1 trout Trash Compactor Repair 1 10-11-2007 10:22 PM
