Discuss
Possibility of low voltage?
 in
General Talk
I have replaced my GE fridge that had a burned out control board, followed by three incidents of compressor failure
Appliance Repair Forum > Appliance Repair Help > General Talk » Possibility of low voltage?
  #1 (permalink)
Old 09-08-2008, 06:13 AM
Junior Member
rmila75 is on a distinguished road
Default Possibility of low voltage?
I have replaced my GE fridge that had a burned out control board, followed by three incidents of compressor failure even after replacing relay and overload. I have heard of similar trouble on the same model of GE fridge.
I now have a new Whirlpool and it's working fine, but I have to wonder: What if I have a wiring or other electrical issue that may be causing a low voltage situation? The fridge is on the same circuit as one other outlet in the kitchen; currently serving a microwave. All had run perfectly for over 5 years before the control board failed, tripping the circuit breaker and starting all my compressor failures, even with a new board. (the new board had it running for 3 weeks before it failed again)
I realize it's best to have the fridge on its own circuit, and I may have that done. But I also worry about the wiring itself, particularly the outlet serving the fridge. I hate to damage another fridge.
Is it realistic to think that a low voltage issue could have developed recently and damaged only the refrigerator compressor? (fan and inside blower were working fine on the GE) I will track down a multimeter in the next day or so and try to test the outlet.
Ads By Google
  #2 (permalink)
Old 09-08-2008, 01:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not think a low voltage could damage the compressor.
It is a good idea to have the fridge on a separate circuit and I would recommend to put a surge protector on the fridge. Power surges created a lot of troubles.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 09-09-2008, 06:23 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
I use the Lowe's surge protector, 1000 Joules, in a blue box and made for Appliances, $12.95
__________________
  #4 (permalink)
Old 09-09-2008, 11:23 AM
Junior Member
Default
Thanks for the advice!
I guess I did not realize that it was acceptable to use a surge protector; I thought the fridge would always need to be plugged directly into the wall socket with nothing in between.
How do the joule ratings work? I just searched online and found one that is 900 joules. Would that be OK for a fridge?
  #5 (permalink)
Old 09-09-2008, 03:30 PM
Junior Member
Default
Here's a bit of an update: I borrowed a multimeter from a friend to try testing the outlets. I have not yet tried the one the fridge is on, but the other outlet on that circuit, as well as several others in the house, show 123 volts. (not sure exactly how reliable the meter is)
Is that a problem? Should I always be under 120 to be safe?
  #6 (permalink)
Old 09-09-2008, 04:05 PM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Most appliances allow a 10% varience so you should be ok there. If in dowbt get a $25 Kill-o-watt meter. You just plug them in and plug the appliance(or whatever) into them and you can check voltage, watts used etc.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #7 (permalink)
Old 09-10-2008, 04:33 AM
Senior Expert
APP Volunteer
Default
You can call this sites parts section for a 1000 Joule surge protector, they should have one. The Joule rating specifies how much energy the device will shunt away from the appliance. Make sure you get one for appliances. A lot of the computer devices actually blow out if there is a serious power surge, thus removing power from the fridg. a nasty surprise!!
__________________
  #8 (permalink)
Old 09-24-2008, 04:54 PM
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
The NEC 2008 (National Electrical Code) requires Refrigerators be plugged into a dedicated circuit, wired 12/3 wire 20 amp breaker.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor.
a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
too much voltage.. jenniferreich Oven Repair (including Ranges and Cooktops) 1 11-17-2009 09:12 AM
voltage to ice maker berkey Refrigerator & Freezer Repair 1 04-19-2009 04:22 AM
no voltage telstaman Refrigerator & Freezer Repair 0 03-20-2008 09:55 AM
No voltage down below gshe461 Dishwasher Repair 0 11-29-2007 11:13 PM
