Discuss
Question about water line to refrig
 in
General Talk
As I start shopping for a new refrigerator, some questions are popping up. I'm wondering about the water line to
Appliance Repair Forum > Appliance Repair Help > General Talk » Question about water line to refrig
  #1 (permalink)
Old 08-26-2008, 12:17 PM
Junior Member
rmila75 is on a distinguished road
Default Question about water line to refrig
I'm wondering about the water line to the ice maker. We currently have an ice maker in our non-working GE top freezer frig. If we decide to get a new unit without an ice-maker but with the hook-up for future add-on of ice maker, will we be able to connect our existing copper water line to the rear of the unit so that it will be ready to go for ice maker installation at any time? Or is the water line connection in the rear considered part of the ice maker kit to be added later?
  #2 (permalink)
Old 08-26-2008, 12:31 PM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
You should be able to use your existing line. Most icemaker install kits come with the appropriate adapters. Just make sure it has a shut off! ;o)
Out of curiosity what's wrong with your GE?
  #3 (permalink)
Old 08-26-2008, 12:39 PM
Junior Member
Default
Thanks for replying. I posted my problem in the refrig forum but got no replies. Here's a copy:
The compressor stopped running in July; circuit breaker for that area of kitchen was tripped, apparently by the frig itself. I replaced the control board myself on this GTS22WCMBRWW model GE refrigerator a few weeks ago because the old board had the usual "burn-out" issue. The new board is the newer version that GE is using as a replacement.
It ran fine for three weeks, then compressor stopped running again; fan continued to blow air. Everything inside got warm.
Repair tech replaced compressor relay and overload. All ran OK for five days and now the same thing has happened all over again; compressor does not run, fan continues to run.
Repair is getting too expensive to be worth it, but I will take one last shot at trying to solve this problem before I order a new refrigerator ( not a GE !)
Can anyone suggest what could be going on?
  #4 (permalink)
Old 08-26-2008, 12:47 PM
Senior Expert
APP Volunteer
Default
Is the condensor fan running by the compressor?
  #5 (permalink)
Old 08-26-2008, 01:07 PM
Junior Member
Default
I will have to try and plug it in again to find out, but I think that it was not running; just the blower that blows the cool air inside was running.
  #6 (permalink)
Old 08-26-2008, 01:53 PM
Senior Expert
APP Volunteer
Default
If that fan isn't running but the frig kicks on then you will need to replace the condenser fan.
  #7 (permalink)
Old 08-26-2008, 04:14 PM
Junior Member
Default
I'm sorry, I was wrong. That condenser fan actually is running. I can feel air blowing out from under the fridge and also the inside fan is running; but no compressor. (the air blowing underneath is cool, not hot like it usually is)
  #8 (permalink)
Old 08-26-2008, 06:48 PM
Senior Expert
APP Volunteer
Default
Did the tech that came out put OEM parts on or subs?
  #9 (permalink)
Old 08-27-2008, 05:53 AM
Junior Member
Default
I'm not sure if he used subs or OEM, but if I had to guess I'd say subs, since they were in a generic looking box that he already had with him.
  #10 (permalink)
Old 08-27-2008, 05:57 AM
Senior Expert
APP Volunteer
Default
Did he by chance leave the box with you? or write the part number on your invoice?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Refrig Compressor Question neonmoon Refrigerator & Freezer Repair 0 01-08-2010 05:57 AM
Installing a Water Inlet Valve to copper water line neilkrenz Refrigerator & Freezer Repair 0 09-27-2009 02:50 PM
Refrigerator Water Line Repair for Ice/Water Dispenser jodijo1968 Refrigerator & Freezer Repair 1 08-21-2009 07:08 AM
water leak in back from water line TRUSTART Refrigerator & Freezer Repair 1 04-05-2009 07:01 AM
Water line on the back of my refrig is leaking KSacker Refrigerator & Freezer Repair 1 04-02-2009 12:55 PM
