| » Gas TANKLESS WATER HEATER no heat |
Sound similar to the problem I ran into recently with an AO Smith hot water heater. The new ones come with a closed chamber. The air supply is through a ceramic filter under the main burner and pilot. If the ceramic filter is clogged or dirty, the pilot and burner will shut off.
On the other hand, it could be as simple as a thermal coupler that has gone bad and needs replacement. Good Luck... |
| Display Modes | |
