Discuss
pellet stove or a propane one ?
 in
General Talk
Have always burned wood, but must be getting old and/or lazy.A dded on a room at the end of the
Appliance Repair Forum > Appliance Repair Help > General Talk » pellet stove or a propane one ?
  #1 (permalink)
Old 07-20-2008, 02:30 PM
Junior Member
FrankMueller is on a distinguished road
Default pellet stove or a propane one ?
Have always burned wood, but must be getting old and/or lazy.A dded on a room at the end of the house, and thinking about either a pellet stove or a propane one. Like the "flick of a switch" with the propane, especially since the wife and kids will be using the room mostly.Would appreciate any comments or input.Thanks, Frank
Ads By Google
  #2 (permalink)
Old 07-21-2008, 02:56 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
I believe wood pellets are much cheaper than propane. Check with a store that sells both.
__________________
  #3 (permalink)
Old 11-03-2008, 04:56 PM
Junior Member
bringselpup is on a distinguished road
Default
Where we live power is a factor. We have a propane log that uses no power to run. Pellet stoves need juice for the auger. It's saved us twice so far in less than a year.
  #4 (permalink)
Old 11-19-2008, 07:31 PM
Fireplace Expert
APP Volunteer
Hearthman is on a distinguished road
Cool choices
Each has strengths and weaknesses.
Pellet stoves are primarily for heat but most do look nice. I have a Quadrafire Castile insert. It heated my 3 story house from March to Thanksgiving using 37 bags and I live in Philly. Daily maintenance simply scrape out firepot with putty knife provided and refill pellets in hopper. Weekly, pull lever to empty firepot into provided ashpan. Annually, thorough cleaning of baffles and venting. Pellets currently about $350/ ton, which should last about 1-2 months for most people. Needs minimal clearances to combustibles. Flexible venting. Awesome heaters. Run off T'stat or remote T'stat. Takes about 20 min. to heat up. Can run unattended as a zone or supplemental heater. About $3-5K installed.
LP is quick and convenient. Can operate off simple low voltage switch, T'stat, or remote (basic or T'stat). Can turn flame down. Realistic logs and embers. Optional convection fan. Flexible direct venting and close clearances increase possible locations and applications. Caution with LP leaks and cost of LP. Listed as a vented room heater so use for zone or supplemental heat.
Check out [url=http://www.fireplaces.com]Fireplaces: Fireplaces.com for gas fireplaces, electric fireplaces, wood fireplaces and stoves![/url] to compare. I strongly recommend an NFI Certified Tech to install either.
HTH,
Hearthman
__________________
Keep the fire in the fireplace.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Converting a stove from propane to natural gas bradburd Oven Repair (including Ranges and Cooktops) 1 12-04-2009 04:12 PM
converting stove from nat. gas to propane lacychoate Oven Repair (including Ranges and Cooktops) 1 10-25-2009 10:50 AM
Stove adapter kit for propane use gijoeri Oven Repair (including Ranges and Cooktops) 0 08-17-2009 08:51 AM
hotpoint propane/electric stove low bottom flame fusion1620 Oven Repair (including Ranges and Cooktops) 3 07-10-2009 08:27 AM
Pellet Stove: reasons to use woodpellets Heating, Ventilation, and Air Conditioning (HVAC) 0 04-16-2008 12:21 PM
