Discuss
In sink-erator flange removal
 in
Garbage Disposer Repair
I have removed the old garbage disposer and now cannot remove the top flange that is in the sink. It
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » In sink-erator flange removal
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-10-2007, 03:21 PM
RonOh RonOh is offline
Junior Member
RonOh is on a distinguished road
Default In sink-erator flange removal
Model Number: N/A   Brand: GE   Age: More than 10 years
I have removed the old garbage disposer and now cannot remove the top flange that is in the sink. It is labeled as an "in sink-erator GE disposer". It looks as if it is part of the sink. Can you help?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-10-2007, 04:05 PM
Junior Member
Default RonOh
Thanks to this forum I figured it out on my own! I looked at the other post about disposal removal and saw the diagram there that was exactly the same as mine. THANK YOU!!! For those wanting to know.... there is a split ring on the pipe that fits in the top of the sink. It is hidden by the flange that has the tightening bolts that scew upward. This flange has a turned down edge to it that covers the splity ring that is actually below it, so just slide it up and expose the split ring and pry it off with a screwdriver. It really was simple once you had the diagram to look at!
  #3 (permalink)
Old 09-11-2007, 05:53 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Great job! Glad we could help...
  #4 (permalink)
Old 12-16-2007, 12:00 AM
Vinski Vinski is offline
Junior Member
Vinski is on a distinguished road
Default
Quote:
Somebody anybody - tell me where to get the diagram RonOh is talking about. I need to remove my insinkerator. Check these symptoms out -
1. It hums but turns freely (it is not stuck).
2. If you manually spin it with the power on, it will start working.
3. When you turn the power off, it will not start again unless you manualy spin it up to speed.
any comments welcome - but I am thinking I could remove the disposal, take it apart and find something inside like the piece of that old dishrag that got caught in there a week ago.
  #5 (permalink)
Old 12-16-2007, 10:07 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
check warranty on your unit, but your start winding circuit is NG ( could be a start cap.. ) better to replace with a new unit ..
__________________
regards
jim
  #6 (permalink)
Old 12-17-2007, 09:26 PM
Junior Member
Default Sounds Right On, Thanks!
Sounds right to me, now that you've explained it. It is probably the starter winding that has burned out and not a failing cap since the power was left on until the breaker tripped more than once. Still, since caps are cheaper...
Tho it's still not working, it still feels better knowing why.
thx again
  #7 (permalink)
Old 06-09-2008, 07:42 PM
twinsmom930@bellsouth.net twinsmom930@bellsouth.net is offline
Junior Member
twinsmom930@bellsouth.net is on a distinguished road
Default
Please give info on how to remove in sink erator that Ronoh (above) asked for an fouind a digram..I need it quick.......
  #8 (permalink)
Old 06-09-2008, 07:43 PM
Junior Member
Default
i need to know where you got your info for removal
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Pump/ Motor removal dudedudeness Dishwasher Repair 4 05-17-2008 01:48 PM
removal of shelf stud gjaffers Refrigerator & Freezer Repair 0 09-02-2007 09:56 PM
Cabinet removal jumbyway Washer Repair 1 08-23-2007 11:07 AM
removing disposal from sink Carnovallp@hotmail.com Garbage Disposer Repair 1 08-13-2007 12:35 PM
Transmission Removal Street777 Washer Repair 0 08-01-2007 04:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
