Discuss
In sink-erator flange removal
 in
Garbage Disposer Repair
It is not part of the sink. Use either a blow dryer on hot or a propane torch to loosen
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » In sink-erator flange removal
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #11 (permalink)
Old 04-03-2013, 04:09 AM
Junior Member
shawn4455369 is on a distinguished road
Default
It is not part of the sink. Use either a blow dryer on hot or a propane torch to loosen the old flange. BE CAREFUL! Most all disposer sink drains are held in by a mounting collar & three screws going up through the disposer unit mounting ring. The sink flange/drain is screwed into the mounting collar from inside the sink,, which is mounted under the sink. I always run @ a half inch round bead of plumbers putty just under the sink flange where the brand name is stamped. Do not use a rubber ring in sink. Remove excess putty after tightening. Good luck. Always run water with unit on for a few seconds after food is down the drain to rinse out any acidic food residue.
  #12 (permalink)
Old 05-15-2014, 10:29 PM
Junior Member
rizzardo is on a distinguished road
Default In sink-erator flange removal necessary?
I am about to replace my badger 5 with an evolution excel.
The sink flange is the same in sink-erator quick mount system and the manufacturer states that it is not necessary to replace the flange.
My flange is 5 and a half years old, and I have never had a problem with it. But I figure if I am going to replace the unit, now would be the time to replace the flange. At the same time, if it ain't broke...
Anyone thoughts would be appreciated.
Cheers!
  #13 (permalink)
Old 06-20-2014, 01:52 AM
Junior Member
natashaB is on a distinguished road
Default
I had a problem with that before. I just ask for help with the garbage collector to know what to do with it.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Unit keeps running after removal of in-sink switch soccerrefth Garbage Disposer Repair 1 08-31-2009 08:30 AM
InSink Erator Hums, Blades Turn, Doesn't Work chinahorse Garbage Disposer Repair 0 03-03-2009 05:11 PM
How do I replace In-Sink-erator 777 Gasket AtlDick Garbage Disposer Repair 1 12-03-2008 11:18 AM
Flange snap ring not holding, specialty flange wranglerbrat Garbage Disposer Repair 0 11-27-2008 10:57 AM
Replace disposal flange redfox Garbage Disposer Repair 2 03-30-2008 01:22 PM
