Discuss
Replacing leaking disposal
 in
Garbage Disposer Repair
I had a drain clog and made the mistake of plunging the garbage disposal. That started a leak. I suspect
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Replacing leaking disposal
  #1 (permalink)
Old 05-15-2008, 11:51 AM
jimdhall2 jimdhall2 is offline
Junior Member
jimdhall2 is on a distinguished road
Default Replacing leaking disposal
Model Number: 175.60552   Brand: Kenmore   Age: 5 - 10 years
I had a drain clog and made the mistake of plunging the garbage disposal. That started a leak. I suspect I damaged an internal seal. There is water leaking out of the bottom of the case. The seal around the sink apprear OK. The label says this is a 5/8 horsepower unit. I see 1/2 and 3/4 units but no 5/8. I'm inclined to replace it with a 1/2, any thoughts? Also, are the mounting flanges universal? I'd rather not replace everything, but just attach a new mechanism to the existing flange if possible. Lowes, which is close by, has Insinkerator disposals are the a direct replacement for the Kenmore? Any hints or suggestions would be greatly appreciated!!!
Related Models
Amana 1750.000 Mwave - Family Size (60 Hz)
Amana 1752.000 Mwave - Family Size (60 Hz)
Amana 1752.001 Mwave - Family Size (60 Hz)
Whirlpool 1765W0A
Whirlpool 1765^0A
Amana 1780.000 Mwave - Family Size (60 Hz)
Amana 18 Freezer - Vertical
Whirlpool 1821W06
Whirlpool 1821^06
Whirlpool 1833W0A
Whirlpool 1833^0A
Whirlpool 1835W0A
Whirlpool 1835W1A
Whirlpool 1835W2A
Whirlpool 1835^0A
Whirlpool 1835^1A
Whirlpool 1835^2A
Whirlpool 1835^3A
Whirlpool 1838W46
Whirlpool 1838W56
Whirlpool 1838W66
Whirlpool 1838^46
Whirlpool 1838^56
Whirlpool 1838^66
Amana 1870.000 Mwave - Family Size (60 Hz)
Whirlpool 1872W0A
Whirlpool 1872W1A
Whirlpool 1873W0A
Whirlpool 1873W1A
Whirlpool 1873^0A
Whirlpool 1873^1A
Whirlpool 1878W26
Whirlpool 1878W36
Whirlpool 1878W46
Whirlpool 1878^26
Whirlpool 1878^36
Whirlpool 1878^46
Amana 1880.000 Mwave - Family Size (60 Hz)
Whirlpool 1883W0A
Whirlpool 1883^0A
Whirlpool 1885W0A
Whirlpool 1885W1A
Whirlpool 1885W3A
Whirlpool 1885^0A
Whirlpool 1885^1A
Whirlpool 1885^3A
Whirlpool 1889W06
Whirlpool 1889W16
Whirlpool 1889W46
Whirlpool 1889W56
Whirlpool 1889W66
Whirlpool 1889^06
Whirlpool 1889^16
Whirlpool 1889^46
Whirlpool 1889^56
Whirlpool 1889^66
Amana 1890.000 Mwave - Family Size (60 Hz)
Whirlpool 1893W0A
Whirlpool 1893^0A
Whirlpool 1895W0A
Whirlpool 1895^0A
Amana 18A Freezer - Vertical
Amana 18B Freezer - Vertical
Amana 18B1 Freezer - Vertical
Amana 18B2 Freezer - Vertical
Amana 18C Freezer - Vertical
Amana 18C3EV Room Air Conditioner
Amana 18C3EW Room Air Conditioner
Amana 18C3HES Room Air Conditioner
Amana 18C3HEV Room Air Conditioner
Amana 18C3HEW Room Air Conditioner
Amana 18C3MA Room Air Conditioner
Amana 18C3MD Room Air Conditioner
Amana 18C3MY Room Air Conditioner
Amana 18C3SA Room Air Conditioner
Amana 18C3Y Room Air Conditioner
Amana 18C5EV Room Air Conditioner
Amana 18C5EY Room Air Conditioner
Amana 18C5V Room Air Conditioner
Amana 18C5W Room Air Conditioner
Amana 18C5Y Room Air Conditioner
Frigidaire 18HA181
Frigidaire 18HA181A
Amana 18M23TA Room Air Conditioner
Amana 18M23TB Room Air Conditioner
Amana 18M33PAE Room Air Conditioner
Amana 18M33PAEH Room Air Conditioner
Amana 18M33PBE Room Air Conditioner
Amana 18M33PBEH Room Air Conditioner
Amana 18M33PCE Room Air Conditioner
Amana 18M33PCEH Room Air Conditioner
Amana 18M53TA Room Air Conditioner
Amana 18M53TB Room Air Conditioner
Amana 18QZ33RC Room Air Conditioner
Amana 18QZ33RC1 Room Air Conditioner
Amana 18QZ33TA Room Air Conditioner
Amana 18QZ33TB Room Air Conditioner
Magic Chef 18RA-3B Rv Range - Gas
Magic Chef 18RA-3BTZ Rv Range - Gas
Magic Chef 18RA-4 Rv Range - Gas
Magic Chef 18RA-4TZ Rv Range - Gas
Magic Chef 18RA-4Z Rv Range - Gas
Magic Chef 18RB-4 Rv Range - Gas
Magic Chef 18RB-4TZ Rv Range - Gas
Magic Chef 18RB-4Z Rv Range - Gas
Magic Chef 18RS-4 Rv Range - Gas
Magic Chef 18RS-4TZ Rv Range - Gas
Magic Chef 18RS-4Z Rv Range - Gas
Magic Chef 18RW-3B Rv Range - Gas
Magic Chef 18RW-3BTZ Rv Range - Gas
  #2 (permalink)
Old 05-15-2008, 10:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
You can replace it with any kind and any make. A new garbage disposer comes with a complete installation instructions.
P.S. If you are going to buy it from a hardware store you can ask for a such instructions to read it prior to purchase the unit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Garbage disposal Patty65 Garbage Disposer Repair 1 05-11-2009 06:20 PM
humming garbage disposal jbntouch Garbage Disposer Repair 2 05-14-2008 10:45 AM
Garbage disposal Andrea Higgins Garbage Disposer Repair 0 03-11-2008 12:53 PM
garbage disposal Dianne Garbage Disposer Repair 1 02-11-2008 02:45 PM
Replacing a leaky disposal with a new one glibritz Garbage Disposer Repair 1 10-02-2007 06:02 PM
