Discuss
Replacing leaking disposal
 in
Garbage Disposer Repair
I had a drain clog and made the mistake of plunging the garbage disposal. That started a leak. I suspect
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Replacing leaking disposal
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-15-2008, 10:51 AM
jimdhall2 jimdhall2 is offline
Junior Member
jimdhall2 is on a distinguished road
Default Replacing leaking disposal
Model Number: 175.60552   Brand: Kenmore   Age: 5 - 10 years
I had a drain clog and made the mistake of plunging the garbage disposal. That started a leak. I suspect I damaged an internal seal. There is water leaking out of the bottom of the case. The seal around the sink apprear OK. The label says this is a 5/8 horsepower unit. I see 1/2 and 3/4 units but no 5/8. I'm inclined to replace it with a 1/2, any thoughts? Also, are the mounting flanges universal? I'd rather not replace everything, but just attach a new mechanism to the existing flange if possible. Lowes, which is close by, has Insinkerator disposals are the a direct replacement for the Kenmore? Any hints or suggestions would be greatly appreciated!!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-15-2008, 09:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
You can replace it with any kind and any make. A new garbage disposer comes with a complete installation instructions.
P.S. If you are going to buy it from a hardware store you can ask for a such instructions to read it prior to purchase the unit.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
humming garbage disposal jbntouch Garbage Disposer Repair 2 05-14-2008 09:45 AM
Garbage disposal Andrea Higgins Garbage Disposer Repair 0 03-11-2008 11:53 AM
Garbage disposal Patty65 Garbage Disposer Repair 0 03-07-2008 11:30 AM
garbage disposal Dianne Garbage Disposer Repair 1 02-11-2008 01:45 PM
Replacing a leaky disposal with a new one glibritz Garbage Disposer Repair 1 10-02-2007 05:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
